Introduction: MK: DIY Drill Press Vibrations #QuickTip
For the drill press to work properly, the belt must be under considerable amonunt of tension. If it is not, there won't be sufficient friction and the belt will creep. The belt is made from rubber and textile core. It's quite flexible, but if you leave it tensioned for longer time, the belt wil deform plastically around the pulleys creating bends, As you start your drill press, these bends will run around the pulleys creating those unwanted vibrations.
Step 1: Fix It!
Picture of Fix It!
Fortunately, there is an easy fix for it! Only thing you have to do is, that every time you know you´re not going to use your belt powered tool for longer time, you simply loosen the tightening mechanism. This means, that your belt won´t be under unnecessary tension, and it wont stretch undesirably.
This also works for other belt driven tools, like table saw. Let me know what you think about this tip or if you have som easy maintenance tricks make sure to share them in comment, subscribe to my YouTube channel, I post QuickTip like this every monday and project video every thursday and don´t forget: get inspired, use what you have and make the best out of it!
mifi (author)2017-01-27
What a great tip! I found that if you can find( like i did at Tractor Supply) replacement pulleys that accept a surpentine belt also is an ideal way to go but on a drill press..you may want the belt to slip if you have a bind...especially working with metal...but i mostly work with wood.....Also ...i cant remember the type of belt i also used to use that i never had the flat spot issue was a lime green colored belt...i will look it up and let you know
About This Instructable
567views
11favorites
License:
Bio: Whats up! My name is Michal and I love to work with all kinds of materials and to create awesome things. I usually work with ... More »
More by MK DIY:MK: DIY Pocket KnifeMK: DIY How to Not Break Taps #QuickTipMK: DIY Rebar Heart #ValentinesSpecial
Add instructable to:
