MM2X Makerbot Replicator 2X Alternative Extruder Installation
Introduction: MM2X Makerbot Replicator 2X Alternative Extruder Installation
The ultimate solution for reliable multi-material and dual extrusion on the Makerbot Replicator 2X
The MM2X (Multi-Material Dual Extruder) is a replacement dual extruder system for the Makerbot Replicator 2X.
It guarantees reliable printing with PLA, ABS and other materials. We have experience and expertise in support and printing with Makerbot printers and therefore took it upon ourselves to improve the nozzle system making multi-material printing with the Replicator 2X a reality. The MM2X kit can be easily installed in less than 30 minutes! and is compatible with MakerBot MakerWare default profiles.
For more information about the MM2X and printing with PLA on the Relicator 2X, please visit
Step 1: Disassemble the Original R2X Extruder
Remove the 4 fan screws in front and 2 screws underneath that hold the aluminium bar in place.
Step 2: Replacing Wiring
Open the wire mesh and remove the original thermocouple wires. Then add the replacement thermocouple wiring and fan cable.
Step 3: Connecting Thermocouple Wiring
The thermocouple wire with the red heatshrink (right extruder) goes into the A connector.
Connect the fan plug to the motherboard connector.
Step 4: Assemble the Bar Mount
Assemble the bar mount using the original screws. The machined lip must face upwards.
Step 5: Insert the Nozzles
Insert the nozzles from the bottom, up. Make sure the wires come up through the slot.
Push on the nozzle perpendicularly to the aluminium bar mount to ensure they are set in the correct position.
Insert the aluminium lock piece, sliding it in place between the nozzles.
NOTE: The cables must exit through the back of the assembly.
Step 6: Re-assemble the Steppers Block
Assemble the steppers block back into place, using the original screws.
Step 7: Mount the Duct
To mount the duct, first slide it with it's bottom up and aligned with the centre of the carriage.
Then screw it to the carriage with a Phillips screwdriver.
Step 8: Insert the Fan
Insert the fan at an angle and twist counter-clockwise to lock it into position.
Step 9: Reconnect All Connectors and Level the Table
Make sure to tighten the springs to lower the table as much as possible.
Jog Z to the bottom of the machine.
Step 10: Insert 'Z' Spacer
Insert the supplied spacer in to the back of the Z platform.
NOTE: The image shows a white spacer, but the one in the kit will be black!
Step 11: Level and Calibrate
- First level your build plate.
- Then perform a nozzle calibration routine to align the new nozzles.
If the nozzles are unaligned please see step 12 for more details!
Step 12: Confirm Alignment of the Nozzles in the Z Direction
If your nozzles show to be unaligned (ie. one hangs lower than the other):
- Start by unscrewing the small screw on the bottom side of the bar mount on the side of the nozzle that is lower; just a bit, you don't have to remove the screw completely.
- Then insert the supplied paper shim/spacer around the rod, in the small gap you opened by unscrewing the screw a bit; in order to compensate for the height difference.
- Re-tighten the loose screw.
Step 13: You Have Assembled the MM2X Kit!
Congratulations! You have finished installing your new Replicator 2X nozzles.
Enjoy using your Makerbot Replicator 2X to print with PLA, ABS and many more!
For more information about the MM2X extruder upgrade Kit visit:
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    What size are the extruder hotend nozzles in this kit? Are they the same as MB Rep2x which is 0.4mm? Also, it's mentioned that these are better for "multi-materials", i'd like to try other specialty filaments such as laywoo-d3 or bronze-fill. will this kit alone allow printing of those types of filaments or will I still need a .5mm nozzle installed?
    Just one word : Excellent extruder set!!!! Excellent shop : RobotSavy... Just one hour to receive an international phone call after a mail for a technical question!!!! First test, a 5H47min print, and it's ok!!!!
    It sure would be nice to have a Replicator at my house....
    Indeed! Makerbots are very handy to have around. Though you don't need to spend all that much to have a decent quality 3d printer ;)
    True that! Both being nice to have a Replicator at home, and that you don't need that much money to have very good 3D printer!
    One needs more money, and the other, more knowledge and skills...
    Honestly, if I could afford, I'd buy a pre-made one, even just to support this community. But I have some skills and as far as I feel able to, I'll let people know how I've done it I'll be really glad to do that. Fair enough as long as I'm using the same community to learn from ;)
    Thank you for this tutorial! even if it's for a specific application, it taught me the advantages of a double extruder! I had a flash that made me to understand what the water-soluble might be used for (structures)! Or just make a double colour piece of 3D :D
    Congratulations for the good work!
    Is it possible to download that two-colored cube somewhere? :)
