Madame Rattatouille lunch sac
 by sunshiine
Featured
Step 2: GATHER AND ORGANIZE YOUR SUPPLIES
WASH AND IRON FABRIC.  DO  NOT WASH FELT!
PRINT PATTERN and cut it out.    www.dltk-teach.com/rhymes/paper_bag_mouse_puppet.htm
Make sure fabric is on grain and has a straight edge.
CUT OUT PATTERN PIECES (OUTSIDE OF PURSE)
YOU WILL NEED FOR CRITTER:
CUTTING TIPS:
Making sure you cut every piece exactly alike ensure better results with less mistakes.  Cut out only 2 at a time ensures better results.  In other words you don't want to layer several different fabrics together and cut a truck load.  By doing it this way each piece will vary in size and shape.
CUT:
1 FACE
OUT OF DARK GREY FELT 4 5/8 INCH SQUARE
2 EARS DARK GREY
1 BUTT DARK GREY
1 NOSE PINK
2 INNER EARS PINK
2 EYES BLACK
2 INNER EYES WHITE
1 PRETTY BOW YELLOW (FELT OR SATIN)
1 CHEESE DARK YELLOW
CUT OUT SMALL HOLES FOR SWISS CHEESE OUT OF PINKING SHEERS OR SCISSORS
1 BRAIDED TAIL FROM YARN APPROX 10 INCHES FINISHED LENGTH OF BRAID
tie with yarn at both ends to secure until later
1 FEW STRANDS OF YARN FOR HAIR APPROX 3 INCHES FINISHED BRAID
tie one end with yarn to secure for later.
MAKE 2 BRAIDS USING  (3 GROCERY BAGS PER BRAID) TOGETHER AND TIE BOTH ENDS TO KEEP SECURE UNTIL LATER.  These will be the bags handles.  I used different colored bags that would pick up the color in the fabric.
1 MAIN BAG OUTSIDE:
CUT:
2 BAG
MAIN COLOR,  MEASUREMENTS: 15 HIGH X 12 3/4 WIDE
2 POCKETS 33 LONG X 6 WIDE
1 FABRIC BOTTOM FOR THE BOTTOM OF LUNCH BAG 12 1/2 X 4 7/8 INCHES
1 CARDBOARD OR (PLASTIC IS BEST)  17 7/8 X 4 3/8 INCHES
LUNCH BAG CRITTER LINING
2 EARS LIGHT  GREY
1 CHEESE LIGHT YELLOW
LUNCH BAG LINING
(INNER BAG)
2 LUNCH BAG LINING 15 HIGH X 12 3/4 WIDE
2 POCKETS 33 LONG X 6 WIDE FOR INNER LINING
2 SIDE INSERTS 4 3/4 INCHES X APPROX 13 INCHES
1 BOTTOM LINING CUT 12 1/2 X 4 7/8 INCHES
LUNCH BAG INTERFACING OR PELLON  THIS GOES IN-BETWEEN THE LINING AND BAG FABRIC FOR SUPPORT.
CUT 2 INTERFACING ( THIS PIECE GETS IRONED TO THE WRONG SIDE OF THE MAIN FABRIC.
MAKE SURE YOU CUT IT OUT EITHER RIGHT SIDES TOGETHER OR WRONG SIDES TOGETHER, THIS ENSURES YOU CUT THEM OUT CORRECTLY.   (NOTE: ONE SIDE HAS ADHESIVE )
USING THE PIECE OF FABRIC YOU CUT FOR THE BAG AS YOUR PATTERN  (CUT OUT YOUR INTERFACING.) FOR THE BAG FRONT AND BACK.
CUT 2 INTERFACING FOR BAG BOTTOM USING BAG FABRIC YOU CUT AS A PATTERN
CUT 2 INTERFACING FOR THE BAG INTERFACING (FROM BAG FABRIC SIDES FOR PATTERN)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
