Step 3Using IAR Embedded Workbench KickStart
In this step I would like to give the basic procedure for using the IAR compiler/debugger. Later in the project we will be tuning the adjustment arrays for the meters to compensate for nonlinearities. We will end up going through this process several times. Also, I wanted to point out steps 3 and 4, which caused me to do some head scratching because I didn't know about them.
1. Open existing or create new workspace.
2. Create new project for Chronulator.
3. Select Project -> Options... -> category: general options and change
device to MSP430G2211.
4. Change Category to "Debugger" and change "Driver" to FET Debugger.
5. Hit ok.
6. Create new file (file -> new -> file)
7. Copy/paste code into new file and name file.
8. Go to the workspace window, your Chronulator project should be there. If not
select the correct tab at the bottom of the window.
9. Right click the project in the tree and select add -> file "your file name .c".
Your file should be added to the project tree.
10. Right click the project again and select Rebuild all.
You can now expand the "your file name.c" branch of the tree and see the
h files that are added.
11. Now to put the code on your chip, select the "make" icon or menu:
Project -> make, or F7 (to make).
12. Make sure that your Launchpad is plugged in to a USB port and that the
Launchpad board has the MSP430G2211 chip on board (or has been connected via
"spy-by-wire" with the project board) and the 32K crystal has been installed.
13. Select the "Download and Debug" icon or menu: Project -> Download and Debug,
or Ctrl+D. This will download the code to the chip and start the debugger.
14. If everything is ok, your computer will pause for a brief time and then a new set
of toolbars will show up. This is the debugger. For the simplest case, we can
hit the "Go" toolbar icon, watch the circuit operation and then hit the
"Stop Debugger" toolbar icon. When you stop the debugger, the toolbar
will return to their normal state.
If you make changes to the code you cycle through steps 12 to 14.
Add Comment
