Step 7: Re-assembly.
Next, take the bearing cone and push it into the pedal body and turn it by hand until it has threaded onto the axle, and then get the 9/16 socket and ratchet, and while holding the cone secure with the socket, rotate the axle by hand until it is tight and doesn't wobble, but not too tight as to squash the bearings into the cones and cups. Then remove the socket and wrench and get the cone washer, put it onto the axle on the inside of the pedal housing, make sure the washer flats match up to the axle flats. Then take the bolt and thread it onto the axle by hand, and then by using the 12mm socket and ratchet, you may need to use the 15mm spanner to hold the pedal thread flats if you need more leverage.
When you have done this, move onto the last step.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
