Introduction: DIY MUSIC CONTROLLED LEDS
Picture of DIY MUSIC CONTROLLED LEDS
hy everyone in this Instructables i will show you how to make music contolled led by simple 1 or 2 steps
its is very cheap i does not require any microcontroller or any such things
Step 1: MATERIALS REQUIRED
Picture of MATERIALS REQUIRED
For making music controlled led you dont need any arduino or any microcontroller yoy just need some LEDs ,
its music controlled leds ,so to light up th leds we need a WOOFER
Step 2: Connecting Leds to Woofer
Picture of Connecting Leds to Woofer
Connecting leds to woofer is very simple just connect anode(+) of the led to anode of the woffer and cathode to the cathode of woofer in fig 2 i had just shown with one led
you can make crazy shape and stripe like which i have done
NOTE : if you are arranging leds in any shape you should connect all the cathode and anode of the led together and the finally to the woofer anode and cathode
UPDATE :I had heard from some people they blew up thier leds by doing this
if your leds couldn't withstand the voltage it is recommended to use resistor
Step 3: Video
Picture of Video
I had uploaded a video check it out music controlled led
if you have any doubt just comment : )
DaBlanch (author)2014-05-02
Just make sure your strand of LEDs are long enough. I've blown many leds trying to do this and the voltage/current was too high.
SuperTech-IT (author)DaBlanch2014-06-22
This can also possibly have the effect of damaging lesser amplifiers as the effect is basically the same as placing a bunch of diodes in parallel across the amplifier's output. Minimally you should have a 100 to 330 ohm resistor on each and every LED.
inkas (author)DaBlanch2014-06-15
use resistors. 5V is too much for these leds.
DCengineer (author)DaBlanch2014-05-04
Have you ever tried wiring it to an auxiliary cable for a computer? Those provide ~5v and have a left, right, and ground channel... should be fairly easy to do assuming you don't draw too much, and you would also have 2 separate sets of LED's blinking.
Gabse (author)DaBlanch2014-05-02
me too :-)
brss (author)2014-06-14
楼主厉害。。。。
楼主厉害。。。。
楼主厉害。。。。
楼主厉害。。。。
楼主厉害。。。。
TSna8 (author)2014-05-23
thanks for sharing such cool idea
regu244 (author)2014-05-23
discooooo
kirankiran67677 (author)2014-05-23
this is awesome
joaqi823 (author)2014-05-05
Sub woofers use DC not watts ?
About This Instructable
6,388views
89favorites
License:
Bio: ignite.innovate.ideas
More by Mayoogh_Girish:Control AC light using ArduinoArduino Bluetooth Basic TutorialHand gesture controled robot
Add instructable to:
