ATTENTION MY FELLOW IBLERS:
DUE TO THE FREE USE ACT UNDER THE U.S. COPYRIGHT LAW, THIS INSTRUCTABLE DOES **NOT** VIOLATE ANY OF SCENTSY'S RIGHTS. BECAUSE THIS BROJECTS MEET THE REQUIREMENTS UNDER THE FREE USE ACT, THIS PROJECT WILL NO LONGER BE CHANGED. THANK YOU ALL FOR YOUR CONTINUED SUPPORT AND SUGGESTIONS IN THIS MATTER!!
I WOULD ALSO LIKE TO STATE THAT THIS IBLE, AS WELL AS THE INSTRUCTABLES WEBSITE IS IN NO WAY AFFILIATED WITH NOR ENDORSED BY SCENTSY.
Thanks
Sokami Wohali
Have you every been to a Scentsy party and saw (er smelled) a few scents that you want, or wanted some scents that you cant get from Scentsy or those knock off brands? Have you ever wanted to buy Scentsy bars but couldn't afford them?
IF YOU ANSWERED YES TO THESE QUESTION THIS INSTRUCTABLE IS JUST FOR YOU!!!
In this Instructable, I am going to teach you how to make your VERY OWN Scentcy bars for ROCK BOTTOM PRICES (for the most part...youll see why in the next step!)!!!
I searched the site for an hour and havent found any 'ibles that even relate to Scentsy...so this is the first and original!! yay me...lol
this project started as a valentines day gift for my wife and then it hit me...AN INSTRUCTABLE!!!
***ATTENTION TO ALL: DUE TO AN ATTEMPT BY SOMEONE TO CARRY OUT THIS PROJECT YEILD THE RESULT OF THE PROJECT BECOMING A SEVERE CASUALTY, I WILL NOT BE HELD RESPONSIBLE FOR ANYTHING THAT HAPPENS TO THE WAX, YOUR WARMER, OR YOUR PERSONAL BELONGINGS IF YOU ATTEMPT THIS PROJECT. IN THE NEXT FEW WEEKS I WILL BE DOING FURTHER RESEARCHING AND EDITING OF THIS PROJECT TO YEILD BETTER PROJECT SUCCESS FOR THOSE WHO WOULD LIKE TO ATTEMPT THE PROJECT. IF YOU HAVE ANY QUESTIONS CONCERNING HOW TO EXECUTE THE PROJECT BETTER (UNTILL I GET THE EDITS MADE) PLEASE FEEL FREE TO pm ME AND I WILL BE SURE TO CONTACT YOU BACK AS SOON AS I CAN. I AM A TRUCK DRIVER, SO IT WILL BE A LITTLE DIFFICULT FOR ME TO REPLY IN A TIMELY MANNER. HOWEVER, IF IMPATIENCE GETS THE BEST OF YOU TO AWAIT FURTHER INSTRUCTION, I WILL STILL not BE RESPONSIBLE FOR THE RESULTS OF THE PROJECT.***
Step 1: Materials
Initially this project may cost as much as the Scentsy bars themselves, HOWEVER it WILL pay off in the long run. if you have the "hardware" already, then this project will cost you ~$1.08 (depending on your state/province's tax rate)
Here is what you will need:
1) A candle in the scent and size of YOUR choice. I personally used the really small one in a glass jar.**
2) A candle "hot plate" or similar item. double boiler works too, just make sure you use a cheap pot.
3) an un-used Scentsy or knock-off brand container (all of the containers are the same really).
4) A container big enough to put Wax In.
5) A Bucket or shallow container big enough to put the Scentsy package in
6) Plenty of time.
**NOTE** The cost of the candle obviously depends on the brand you use and the size!!!
Step 2: Preparation PT. 1
What you are going to do now is important to making the bars...
First plug in your hot plate and let it warm up. next, take your candle and using a dremel, knife or some other means (i used a dremel but i had no time) scrape out the wax and put it into the container for wax. it is important that you minimize the big chunks of wax, as they will slow down the melting proces of the wax. What you really want is for the wax to be as "powdery" as possible. if you end up with a few big chunks, just pick em out and then get them as small as you can possibly get. when your done with scraping the wax out, put the candle jar on the hot plate. if you left a little residual wax in the jar, thats alright as it will melt and help the melting process and keep the jar from over-heating and breaking.
Step 3: Preparation PT. 2
After a few minutes the residual wax should have melted...take as much of the powdery wax and fill the jar as full as you can get it without causing problems for the hot-plate (such as wax falling onto the plate and causing a fire. if this does happen, sit there and wait for the wax to burn off the plate, and then you will be ok to leave the room). HOWEVER MONITOR THE WAX/HOT-PLATE!!! AT ANY POINT SOMETHING CAN GO ASCUE AND A FIRE CAN BREAK OUT.
Whenever that bit of wax is melted, keep putting in more and more wax (little to big) until the jar is as full as you can get it...again, without causing problems for the hot-plate.
This is really a waiting game now.
Step 4: Pour The Mould
Now it the tedious part...you will now  take the melted "vat" of wax and pour it into the Scentsy container...you need to be quick BUT CAREFUL. this stuff is hot and if not poured fast and carefully enough will get all over, and will be wasted. once you pour the mould you cant just melt more and add to it. it will cool and set too fast. i had to learn the hard way (just refer to my pictures and you will see the "mess") You WILL get some of the wax on the surface your working on and in the nooks and crannies of the mould.
Step 5: Rapid Cooling For The Impatient
Now if you want to finish the project faster, you will have to take the bucket, or containter just bigger than the Scentsy package and fill it with water to just below the rim of the package opening. you dont want water getting trapped in the wax. Now close the package and in a level manner as to not spill the wax, put the "assembly" into the container with water. leave it in there for ~1/2 hour or so. By this time the water will have cooled the wax to a hardened state. when you feel its fully hardened, you can take the packaging out of the bucket/container. now wipe off the water from the package.
Step 6: TADA!!!
Now you are finished with your Scentsy bar...below i have includes pictures of the bar not ready, and a bar that is ready to be taken out of the mould...after you take the bar out of the mould, crack off the residual wax and either keep it for later, OR throw it away (which would be a sheer waste.
1-40 of 52Next »
dsammut-bryan says: May 5, 2013. 4:42 PM
I like your detailed instructions. I tryed it and it worked great! I have also used an old vintage type ice cube maker. That works too. Thanks for you reusable instructions! Love it!
sokamiwohali (author) in reply to dsammut-bryanMay 15, 2013. 6:36 PM
sorry for the late reply. Thank you very much for the compliment. and i am glad this project was a success for you. thanks for feedback on the ice cube maker. what was the result of that? were the "wax cubes" just the right size, did you tinker with the amount of wax you put in the cube maker?
dsammut-bryan in reply to sokamiwohaliMay 15, 2013. 8:29 PM
Yes I used a little bit less than half
ScubaKitty says: Mar 2, 2013. 1:46 PM
Call them Warm Waxies, Biscuits, etc....be creative! :)
kdavis17 says: Jan 24, 2013. 6:41 AM
Just call your ible "Make your own wax fragrance bars for warmers". Take out all references to the brand name; make sure it's ok to use the picture of the brand mold without actually referring to it's name. I found it a very easy and do-able instructable.
cvalentine3 says: Jan 9, 2013. 1:02 PM
I have found that breaking off chunks of the candle or cutting it into small pieces works just as well and saves a LOT of time.
Another suggestion: if you are going to use this method and you want the wax to be as powdery as possible, I've found that using a zester or a very fine grater works extremely well. They sell small ones with handles on them (they almost resemble a spatula) at the local dollar store here and they work great!
cvalentine3 in reply to cvalentine3Jan 9, 2013. 1:04 PM
And please be aware that I am in NO way trying to prevent anyone from trying your method. :)
sokamiwohali (author) in reply to cvalentine3Jan 13, 2013. 9:53 AM
great suggestion actually!! the problem for when i made the ible was that i was trying not to break the glass the wax came in so i could use it as a vessel to melt the wax...if you have wax that is not in a glass jar your method would work fine. in fact i bet spooning out the wax would work well too.
Also thank you for the idea of the zester...i would never have thought on this!!
Chrissyloo says: Dec 28, 2012. 11:32 AM
OK, I read you warnings concerning Scentsy. Here is the thing; have you contacted an intellectual property attorney? I would change your title to "Make Your Own Wax Bars For Your Scentsy Warmer." or something comparable, are you following me? I'm sure they are trying to tag you on patent infringement, trademark or copyright infringement, but they don't have a case and here is why; you are not selling the product therefor, you are not infringing upon their product. Another thing, Scentsy's method is posted on the USPTO (United States Patent and Trade Mark Office) website, anyone is free to go look to see how they do it as long as they don't sell it, they sure can make it for their personal use. Also, if you write this up as a review of Scentsy with a "but people can make a comparable product at home for less," you are more so protected because you are free to critique methods, etc... As long as you keep it "Compared to Scentsy." You are fine because otherwise Coke-a-Cola would have numerous causes against every other cola manufacturer, especially generics who often advertise "Compared to Coke-a-Cola." You get it...right. The news would be in trouble as well because they often report on products and then turn around and tell the consumer other methods to save money or be more effective. I won't purchase from Scentsy because I have had nothing but negative experiences from pushy and arrogant reps. I like their product, but it's like purchasing Mary Kay from a rep. Once you pull that trigger you find yourself being constantly bombarded, annoyed, harassed, and begged to no end. They create people who inadvertently make others dodge them like the plague.
sokamiwohali (author) in reply to ChrissylooDec 30, 2012. 6:52 PM
your right in some aspects. according to the us copyright law i am in no way required to change anything in this project pecause i am using it under the "free use" clause of the law. this allows me to use their name in any matter that i feel so long as i am not using their name to endorse what i am doing for my own profit or personal gain. i am also using their name for educational purposes. because these three requirements are being met i am not legally required to change anyhing in this project. an as such since then they have not bothered me. so in a little while i will be adding the name back to the project as i originally had it. i spent long hours studying the US Copyright law, and had even contacted a copyright lawyer for consultation and they confirmed everything that i have stated.
sokamiwohali (author) in reply to sokamiwohaliDec 30, 2012. 6:55 PM
also before making this project i had no idea that i could just go and look at how they did their stuff...cause honestly i dont care. i thought about my own way to do this and executed it.
tabbysdg says: Dec 11, 2012. 10:15 AM
i have tried this, some candles (the softer soy based waxes) worked ok.. others, the scentsy warmers didn't get hot enough (which is a good thing, the warmer should never get too hot) to melt them properly.. but i guess my question here is why melt them down and put into the other container?
YOU could also melt the wax in the candle container by sitting it on one of those candle warmer bases.... however i have also tried this and i had a giant hot jar of liquid wax that i didn't want to touch...so maybe melting it in another pot is the way to go...
i have just broken up or cut off from the candles that i tried this with.. and i am a consultant by the way.. i have a non scentsy warmer (shhh) lol, and it burns hotter than my scentsy warmers, so i found the hard wax candles do work better in it... however i am a bit leary at how hot it gets so i monitor it and am always near it if i am experimenting like this...
and to jcasey6 - note that the instructions on line for the brand of warmer at wal-mart state do not leave unattended and do not operate overnight.. so please be safe.....
and don't be so hard on us Scentsy consultants!!! we are only truly trying to sell a great quality product that we all believe in passionately and to make an income for us and our families... no different than any other sales based business from cars to cakes....
I can buy shoes at wal-mart or shoes at a designer store, both are shoes, but the difference in quality is apparent!!! and we all often know that you get what you pay for and most of us are ok with that.
sokamiwohali (author) in reply to tabbysdgDec 22, 2012. 8:16 AM
What i said about the scentsy consultant is not meant for everyone, but if thats the way you took it, sorry...you seem like you know better when it comes to this, and so i think it does suprise you that a scentsy consultant was not smart enough to do that the instructions that came with the device said...to let the wax cool and then peel it off...no harm would have come. now as far as trying to make income and selling a truly quality product, your right. that is what most of you are trying to do...and i applaud you all who live and let live, but my comments were targeting those who just want to rag on other ppl and make others miserable cause they dont like someone elses idea on how to make the most of what you have. the idea behind this project was for ppl to be able to make bars similar to the scentsy product so that they may use more scents that scentsy doesnt offer. for example, the scent i used in this project, i know for a fact scentsy has never made...i cant remember the name, but i know that they have never made it. my wife loved the scent and therefore a new "ible" was born.
so as you can tell, this product is not meant to tank the scentsy brand (otherwise mainstays, scentsaionals, and a few other brands would have already tanked them because of the affordability of those brands compared to scentsy).
jcasey6 says: Nov 18, 2012. 10:27 AM
I have a walmart wax burner and have done this before :) it does melt the wax and makes the house smell good! I had one of those big candles that have the 3 wicks in the middle and i took the wax that broke off and placed it in the wax warmer. it lasted a few days (but i leave mine on 24/7) so if you dont leave it on, it wil last alot longer :)
abergeron says: Nov 8, 2012. 10:20 AM
I can't help but think a lot of the negative nellies are Scentsy consultants or are close to those that are...
First of all I'm a big supporter or direct sales since I've been it myself for 8 years, but if you've found a cheaper way in this economy more power to you! I would do this if I had more motivation since most Scentsy scents are too strong and give me a headache. I personally wouldn't use these in my Scentsy warmers because they are too expensive too chance on ruining, but you can get warmers at walmart for around $10 that take a regular (not $1 each) light bulb that would work with any of the wax you use.
Thank you for taking the time to try this and share it with us! It's unfortunate that there are those out there that would ruin this for others for their own financial gain.
sokamiwohali (author) in reply to abergeronNov 9, 2012. 7:02 PM
well, its go figure though...they compliance lady that i talked to was a real...well butt hole...as everyone on this site can see, nowhere did i mention that i wanted to make money off this, and in no way was i expecting to...i am not saying this is what you were saying about me, i am just saying...whats really funny though is that Mainstays, and Scentsationals have an EXACT replica of scentsy, yet nothing is being done to them, but lil ol me is getting piced on cuz i found a way to make scents that scentsy doesnt offer or discontinued...this is the world we live in now...unfortunately...thanks you for your sweet comment though its much appreciated.
texasgirl1976 says: Sep 4, 2012. 2:09 PM
This will not work for the Scentsy warmers due to the fact that they do not get hot enough to melt the wax from most candles. Scentsy uses a wax that has a low heat melting point for their warmers. They do sell warmers at Bath and Body work and a few other places that would get hot enough for this to work with. They are electric warmers made for use with scent tarts. Scent tarts are most often made from the same type of wax that is used in most candles. So this should work with these electric warmers where they are most likely to fail with the Scentsy warmers. I think the warmers are between $10-20. The one tip I have for those of you who have Scentsy warmers and want to be able to make your own scents is to reuse your wax and just add drops of essential oils to the wax after you place it into the plastic container so you can determine how much scent you want each block to have. You can experiment with scents and smells and add less or more essential oil depending on how strong you want them to be. I hope this is helpful.
abergeron in reply to texasgirl1976Nov 8, 2012. 10:24 AM
Great idea! A lot of their scents are too strong for me anyways and I'd rather use essential oils.
sokamiwohali (author) in reply to texasgirl1976Sep 6, 2012. 9:27 AM
it will work. but for only certain candles. if it didnt work for the brand i posted, i wouldnt have posted the ible.i have used my wife's scentsy warmer to test this project 3 times on 3 candles. it works every time for certain types of candle wax. i do not post ibles without first making sure that it works. if it doesnt work, then i simply dont take pictures, and i do not start the editing process. i have already mentioned on this instructable that NOT ALL candles will work with this project. PLEASE READ THE WHOLE IBLE and not just one page.
texasgirl1976 in reply to sokamiwohaliSep 6, 2012. 12:48 PM
My comment was not intended to say your instructable was wrong or inaccurate as a whole. I was only trying enhance this project with a few suggestions so everyone would be able to get the most out of this wonderful instructable. I said most candles not all may not work. I did read the whole instructable. I just wanted to help maybe expand the amount of people who could benefit from this from experiences of my own. Sorry you felt I was stepping on your toes.
sokamiwohali (author) in reply to texasgirl1976Sep 6, 2012. 1:26 PM
hahaha...my bad i am sorry, we both stepped on each other's toes...i didnt see the "most" part of your comment.
To clear up the murky water here, just like ive said many times in comments and the ible itself, your right, most wont work. if you buy a decent brand candle, it is certain not to work. i use mainly mainstays brand from walmart.
I think we both could definately agree to NOT USE STRAIGHT PARAFIN WAX i do know that parafin is a hard wax, and wont work as well (if at all) with a scentsy warmer. But that is a good idea to use wax and essential oils to make the bars with. either way the work load is about the same.
Markeighs Mommy says: Sep 12, 2012. 2:48 PM
Just as an FYI, not saying this isn't a great idea, but if you use this in your authentic Scentsy warmer you will void the warranty that comes with them. The only things you can use in their warmers are actual Scentsy products. Their wax is a "food" grade wax.
sokamiwohali (author) in reply to Markeighs MommyOct 12, 2012. 8:54 AM
well, this isnt meant for just Scentsy. it could be for any warmer that can get hot enough to melt the wax, or simply for a flame based burner.
Nomianca says: Sep 4, 2012. 3:06 PM
Great job! I think the Instructable is very well done, however, I also think that in time this could get pricier than a Scentsy bar or equivalent. The "scent throw" from less expensive candles is NOT the same as a Scentsy bar. In the end you end up buying two or three times as many because they lose their smell considerable faster.
sokamiwohali (author) in reply to NomiancaSep 6, 2012. 9:38 AM
thank you very much Nomianca. it really depends on many factors such as brand, wax composition, etc. the candles i use are the knock off walmart brand...mainstays i believe...what ever the brand i use, i have found that the knockoff candles are best to use for this project as MOST of their scents havs a composition VERY similar to that as Scentsy(not only that, but the candles are $1.00 each, and if the pfoject fails, you can always make something else out of the wax, like pouring it back in the original container and sticking the original wick back in and using it as a candle...so really its not a 100% loss). Burn rate for even Scentsy brand cannot be relied on as the scents, and wax they have to use need to be "compatible" so to speak. if not, it will burn too fast, too slow, or it wont burn at all. i am sure they use a consistent mixture for everything, however like food, and paint and other products out there, every batch is different.
SweetOnScents says: Aug 5, 2012. 2:30 PM
hmm sounds complicated. Is the wax non toxic?
sokamiwohali (author) in reply to SweetOnScentsAug 20, 2012. 2:11 PM
Its not complicated... short form:
1) Melt candle wax.
2) Pour Candle wax into mould.
3) let wax harden.
4) melt in scentsy (or knock off) warmer.
kjones-bugajski in reply to SweetOnScentsAug 11, 2012. 5:31 AM
soy wax is not toxic it's made from 100% soy bean oils, I've been working with soy wax for several years and love it
Shorties63 says: Aug 21, 2012. 6:09 AM
I started buying the knock off's and I used a Potpourri burner with a tea light candle and it worked great. I paid a $1.00 at a dollar store and $2.00 on the scented wax cubes. so i think I'll try this just to see how it works.
anglinn says: Aug 20, 2012. 11:04 AM
So I tried this and it does make cubes but they wouldn't melt right in my scentsy warmer, it left a mess and ruined the dish thing. I called my scentsy lady and and she said it's because they use a different wax not the same as candles so it melts at a different temp. So needless to say it cost me more cause it voided my warranty and I had to buy a new top for my warmer and the cost of the candle and warmer plate. It might work for other brands but I would not recommend it for scentsy brand stuff.
sokamiwohali (author) in reply to anglinnAug 20, 2012. 2:09 PM
(removed by author or community request)
anglinn in reply to sokamiwohaliAug 20, 2012. 6:48 PM
Um... no offense but did the Eagle Scout just tell me I "should NEVER tell the truth" the scentsy consultant is my sister and I don't feel comfortable lying to her. I know the scentsy also use a lower wattage bulb than most other electric warmers. I'm not trying to promote or tear down any company I was just simply trying to help save another honest person some money if they use a scentsy brand warmer.
sokamiwohali (author) in reply to MsJanAug 20, 2012. 2:17 PM
iwtw says: Mar 23, 2012. 3:01 AM
can we use ice cube trays?
xanadu020 in reply to iwtwAug 4, 2012. 10:52 AM
I have used an ice tray that was meant for ice cubes for water bottles and cut the stick in three's and it matched the size of the scentscy bar cubes quite well. Make sure you find a tray that has a cube shape similar to the size of each portion you break off on a bar.
sokamiwohali (author) in reply to iwtwMar 23, 2012. 6:17 AM
im sure you could, but its questionable. ice cube trays are WAY bigger than Scentsy packaging. This presents a slight problem in that the scentsy packaging allows for the "reformation" and integration of the unused wax back into the original bar. BUT an ice cube tray doesnt allow for that, as the "scentsy cube" would be HUGE and the Scentsy bar would be even greater...just one of those cubes is equal to about 4 or so individual scentsy squares. If your scentsy lamp isnt that big, the wax will simply overflow and cause a fire hazard...Great idea, but to be safe i think using either a Scentsy brand, OR knock-off scentsy brand bar packaging...If you live in the U.S. and you have a walmart, the initial purchase (~$2 depending on which of the 2 brands you choose) of a simple knock-off in your favorite scent will benefit you in the long run cause all you have to do is use what is already in there OR take it out and pour your own mould, let it set, and then take that out and replace the original wax after clean up. seems like alot of work, but the biggest portion of work is waiting for the wax to melt...which for the size candle i used took at least 1.5HR. The bigger the candle the longer the wait.
hannahodgepodge in reply to sokamiwohaliJun 16, 2012. 3:24 PM
Do you think an Ice cube tray that makes "mini cubes" would work? And also would putting wax paper over your working area help with the mess? I usually pour melted wax back into my molds over my bathroom counter, and when I spill I can pick the wax off of the counter once its hardened and stick it in the mold... just a tip :)
sokamiwohali (author) in reply to hannahodgepodgeJun 18, 2012. 3:08 PM
honestly, idk about the mini cubes...didnt even know they existed...if you could find a link for they type that you wanna use, ill look at it and then get back to you. one thing you have to remember though is that certain materials are made for certain temperatures, and if you use an ice cube tray, the hot wax MIGHT melt or distort the plastic mold. thats why you can re-pour the wax into the original packaging of the scentsy and scentsy knock-off waxes.
As far as the wax paper...great idea!! that would work on a surface that you didnt want to get wax on. I do the same as you, i pour in the bathroom. BUT i dont spill alot of wax :)
Gardengurl says: Mar 30, 2012. 8:16 AM
What is the Scentsy for? Like a refreshner?
sokamiwohali (author) in reply to GardengurlMar 31, 2012. 7:41 PM
IDK what it is really...i guess you could call it a wickless-flameless candle. You can buy kockoff warmers @ walmart for like ~$20 or less...i think scentsy brand is considerably more than that. You have the warmer which uses a lightbulb to create heat, and there is a warming plate that you center over a hole in the warmer...the lightbulb heats the plate which in turn heats the wax and allows fragrance out into the air.
1-40 of 52Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
