Mac Gyver BigLedLamp
Published
Introduction: Mac Gyver BigLedLamp
About: le Libre choix de savoir et de le dire aux outres
Some pieces from the bind ....
Step 1: Building...
You need:
1 led cob 5w (led cms/d !! this type have very white light) 18 volt
1 on off switch
2 battery 9volt
1 little radiator aluminium from pc
some wires,soldering materials,other for build your project like you want....
soldering two wires on led and join batteries in serial(9+9=18 volt),add the switch and fix the led on the base of radiator(dont worry,you can touch the led....the surfaces is low temperature),build a lamp how you want....
this project is for everywhere,every want,you only need to add some fantasy....
thank you to watch...good luck,oups good light......
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    The LED will finish off the batteries in no time... 9V batteries have a pretty low capacity.
    18650 batteries or 12V Lithium-Ion batteries could be way better (Check them on eBay, They're really cheap)
    sure!! depending of usage ......(https://en.wikipedia.org/wiki/Nine-volt_battery).
    in my case,have light for one hour....(maybe is battery at 300 mAh...)
    this led need 275 mAh......We can build a battery pack with others battery keeping in mind the type of usage you needed...!! emergency lamp(short time)
    exploring lamp or diving lamp(long time)....
