loading
Apple really dropped the ball on the design of this charger. The wimpy wire used in the design is simply to weak to take any real stress, coiling, and yanks. Eventually the rubber sheath separates from the MagSafe connector or the Power-brick and the wire begin to fray or short, sometimes affecting charging and sometimes smoldering. If you use the tabs that fold out and allow you to wrap the cord around the brick you are probably reducing the life of you charger.
You may want to take your charger to apple straight away and see if they will replace this charger. I would cite reviews on the apple store website if they do not replace yours. If they do not replace it then start working on this instructable. Apple knows about this problem, but they have done noting to remedy it. This instructable is to provide hope for people who must forgo grocery shopping this week if they plan to buy a new charger. You can do it! Apple you should be ashamed of yourself....... show your loyal customers some mercy. You must be making a killing on these chargers.
In this Instructable I will cover opening the power brick case via brute force.
Preparing the Magsafe connector for soldering/ soldering.
Preparing the Power brick for soldering/ soldering.
Skills Required:
-Adventurous case cracking
-Exacto surgery
-Hot glue sculpting
-Soldering wires
Materials necessary:
1. Pliers
2. Screwdriver
3. Exacto Knife
(Skilled use of a dremel could save you a lot of time too!)
4. Electrical Tape
5. Soldering Iron
6. Hot glue gun
7. Love for going where you shouldn't.
Step 1: Quick Work - Disassembly of Magsafe Connection
The MagSafe connector was already frayed free of the wire on my charger. But I did not have near enough wire to solder back onto. The aesthetically pleasing body of the connector needs to come off.
Out come the pliers (Slide lock in my case) to crush it off. Be careful not to damage the magnetic metal contact up front. We will still need to dig into this further to expose enough wire to solder to.
Step 2: Disassembly of Power Brick - Brute Force Attack
You guessed it. This case is also molded or epoxied shut. No tabs to even break, so go at the seams with a screw driver. You may choose not to chew yours up as much as I did, but i don't care much for this over-designed block. An average power charger is a pretty average task for most companies, this is what happens when you apply "form over function" design.
Underneath where the plug prongs slide in I found a weak spot where the seams have some give. If i had a thinner screwdriver I may have been able to avoid the next step. I used an exacto knife to shave the seam wider to slide my screwdriver in. Once in, give it a bit of a twist and the seam should crack open. This was a very noisy process for me.
This is where slow and delicate can save you a lot of cosmetic damage, but that was not my priority. Work around the case cracking the seams apart, being careful not to actually crack the case. Pretty much a clam-shell design so once its free it should slide off easily.
Step 3: Prepare Brick Wires for Solder - Not So Easy
The stress relief did save the connection where the wires were soldered into the circuit board inside.
** You may choose to de-solder the two wires from the circuit board, but this will reduce your cord length a bit. Also, there is not much room to maneuver an iron at the contact points. Individual mileage may vary.**
Snatch out that exacto with a sharp blade. Shave bits and chunks out to expose the wires underneath. Be careful to damage as little of the wiring as possible or you may have to end up soldering directly to the circuit board and there is not much room to maneuver in there.
Re-strip your wires for soldering back together. There is an inner coated wire and and outer uncoated wire, they are pretty obvious.
**Remember to save the important electro doo-dad.
Please, Please, be careful and try not to cut yourself. Don't let this charger beat you.
Step 4: Repair on the Power Brick Side
You may opt to unsolder the frayed wire at this step and solder directly to the circut board. I even recomend using aftermarket wire here because the mac wire is quite lame.
I chose to cut, strip, clean, and tin the existing wires on both sides of the joint.
Tape or use heat shrink tubing on this joint. Remember not to leave too much extra wire around the joint because we are going to stuff it all into the case before closing it up.
You may opt to super glue epoxy your case shut. I just snapped it back as well as possible and gave it a healthy dose of electrical tape in case I ever need to check on my solder joints. I also tightly wrapped about and 1.5" of wire to the body of the brick to act as a strain relief.
Step 5: Repairing the MagSafe Device
I removed the rubbery plastic that is used to secure the joints enough so that I had something to solder to (soldering iron melting and exacto surgery). Split the outer sheath wire into two equal groups and tin them to connect to the two points on the MagSafe. Solder your connections and use electrical tape on the unshielded wires to protect from shorts.
I used hot glue, making sure to apply at least the first large blob all once in one blast to ensure uniformity. In reality i think that I always pull on the cord to unplug the charger so I opted for hot glue hoping it would take better straight on yanks vs shrink tubing's side-to-side protection (who knows though). If you use heat shrink tubing instead (which I have had good results with in the past) make sure you slip it on before you start!
Congrats on fixing a problem Apple should have never had! Please send me your ideas on how to make this a more friendly process, I would be very interested.
Good Luck and I hope the new breed of chargers doesn't cost 79$ or fail so easily. Its curious to because this could be a potentially dangerous flaw too.
This is my apple mac charger help mreeee it won't charge at all and my laptop is dead and needs charging! I live no where near an apple store too
<p>I have two adaptors, one 65 W and the other 85 W. The cable for 85 W adaptor is damaged, Can I replace the damaged 85 W cable with the cable of 65 W working adaptor? </p>
<p>If you are having problems with the joint fraying (the brick to skinny cable) check out the Brick Boot! it works extremely well and is less pricey than alternatives or buying a new cable!</p><p>https://squareup.com/store/brickboot</p>
<p>Nice...it works for me...thanks dude...by the way, iam from Mozambique (Africa). and im not monkey, iam IT.</p>
<p>Really helpful! <br>i have one question ... can u tell me the Watts of the electric soldering gun that u use??</p><p>thanks!!</p>
<p>Just wanted to let you know you can buy a whole new cord to replace the damaged one on amazon for around $20.00 including shipping I just bought the first model cord and it cost me about $16.00 with shipping. </p>
<p>Great guidance. Thank you so much for posting.</p>
<p>Its pretty dangerous. Did it work for you afterward? I expect it did. My Macbook adapter didn't work before and i didn't repire it.I bough a new one from <a href="http://www.eachbattery.com/" rel="nofollow">here</a>. It is a great source for OEM chargers if you can find them.</p>
<p>Unfortunately those aren't OEM, and the non-OEM ones aren't worth buying.</p>
<p>Hey Everyone,</p><p>I went through 3 chargers the first year owning my Mac before I found out I could buy a product called a Python Cord that prevented Mac chargers from breaking at the base of the charger.. Lesson learned.. Hope this helps someone!</p>
<blockquote>If your cable is cut off, look here http://www.macbookchargers.net/</blockquote>
Hey, is there any way to replace the actual prong part on the Magsafe connecter? Mine actually burnt out (which is definitely not safe, as the name for some reason implies). maybe i should be innovative and make something up, because honestly I only have time to lose. I am almost sure it has nothing to do with the power brick, nor a broken wire. I actually had that problem with my last charger, which was mac brand. This one's a cheap replacement.
Keep always a spare adaptor in your circle of friends.
Thy ... I was surprised to see there are indeed only 2 wires. I thought it needed more wires to make a red, orange and green light work.
This is a fantastic fix it.&nbsp; Thanks for being bold and trying it out.&nbsp; One thing that helps with the aesthetics (as if that matters at this point) is to use white electrical tape intead of black.&nbsp; It works and looks a lot nicer than wrapping your brick with black tape. <br />
Hey Abe, <br> <br>Aesthetics wasn't my priority (you might be able to tell). But a good tip nonetheless!
Hi,I have connected the wires as shown in the picture no 4 and I tried to connect to my macbook before I start to solder it down.However the light shows green instead of red which indicates that it's not charging.Does it mean that I have made a mistake in some steps?Please advise.Thanks for the instructions.
Hey vvwwuu! <br> <br>I believe the green light means that the cord is successfully connected and that your battery is already charged. If orange it means you're connected but your battery is low.
@ardnon <br>According to my information there are some very minute springs behind those pins which due to physical stress/improper use/ or any other abuse get misaligned or broken? and are not serviceable due to their small size and the way the connecter is made. I had the same problem with 3 of my chargers, but didn't find any solution for it. In the end had to order a 10$ &quot;t&quot; connecter cable for macbook charger from eBay and then changed the complete cable. In my opinion the &quot;t&quot; type connecter is better than the &quot;L&quot; type connecter specifically in regard of this problem.
anybody have a fix for when one of the pins doesn't pop back out all the way on the end that plugs into the computer? It's not stuck all the way in, just doesn't come out quite far enough to make the connection, and can be pulled out with tweezers but pops back in part way.
Does the outer cable (the wire that &quot;wraps&quot; the other one) goes to the GND on the board ? Just messed that a little too much...
Yea, the outer cable is the GND (ground). The white one is the positive.
Hi! Love the guide, it came in very handy for me. However, there is a guide here that results in the repaired Magsafe Adapter looking like it was never opened at all: http://warrantyvoidifremoved.blogspot.ie/2013/04/repairing-charredburnedbroken-cable-on.html
Please clarify this? In picture 4 above it looks like the wires are divided into 3 bunches. Then the next pics look like it gets soldered back as 2... I soldered mine back as 3, and it works great for power but doesn't charge. Were the 2 bunches of loose wire supposed to go together? <br>Thanks
To remove the plastic mold just put the plug in a vice sideways and gently do it up until it comes off the wires then snip it with cutters. Don't over-tighten it as there is a PCB inside and don't put the thin white centre band in the vice jaws as this is part of the plug and it will break.
I LOVE YOU :D <br> <br>Saved the day you bloody wonder! :)
Thank you so much
I managed &nbsp;to remove the &quot;aesthetically pleasing body of the connector&quot; without damage. If you place the metal part of the magsafe into a vice you can then use a small screwdriver to prise the plastic housing off.<br /> <br /> I then used a scalpel (exacto knife) to carefully cut the translucent blob off to&nbsp;expose the internal circuit board to make soldering easier. This was done with a single cut to one of the short sides and then simply peel it off.<br /> <br /> Once I unsoldered and soldered the wires back on the plastic housing (along with the rubber boot) just clicked back into place. However, i could not get the translucent blob back on.
I used Exactly the same method, except globbed hot glue on the circuit board and trimmed with a razor blade to allow the &quot;Body Connector&quot; to press back on. I then &quot;corkscrewed&quot; the spring from a pen onto the wire and wrapped the end where the wire (with spring) meets the &quot;Body Connector&quot; with electrical tape so that I had created a cavity which I then filled with hot glue. <br><br>
I have this charger but is brand new and i not need to fix but i whant share one thing that i made on my old hp charger.they broke the wire exacle the same way and i found a way to open that whit no damage at all , i put a knife betwen the two parts and tap on the back of the knife until a hear a snap from the glue i make this all around and open that leave no marks on that .
My dog chewed through my charger, so i used dads spare one until this morning when he chewed through that one as well ahhhh. In both of the charges the break is mid wire. I have tried to reconnect the cables but this did not work. Any suggestions what am i doing wrong?
Apple just settled a class action lawsuit and is now replacing these for free: <a href="http://cnet.co/tl5p4W">http://cnet.co/tl5p4W</a>. I walked into the Mac store with my crappy one, they made me sign a document and then handed over a new one. Simple as that.
Apple just settled a class action lawsuit and is now replacing these for free: http://cnet.co/tl5p4W. I walked into the Mac store with my crappy one, they made me sign a document and then handed over a new one. Simple as that.
I had no idea that other people did this or had this problem. My mom came to me and asked me to fix it so I said &quot;I'll see what I can do,&quot; not knowing what the problem really was. I used nearly the same method but hers was only bad on the connector end. I ended up desoldering and resoldering directly to the connector without damaging the LEDs. Hot glue worked for me too. Awesome thing was that my mom had issues with her hard drive/data recovery later and needed to take it in. it wasn't covered by the protection plan at this point but the mac store guys were so impressed that both the charger and the leds still worked that they repaired everything free of charge. I guess being creative and cheap paid off eh?
Thanks so much for this. You saved me, a grad student, $ needed for rent &amp; ramen noodles. Eyebrow tweezers (the kind that open like scissors) came in handy. I also like the bandaged look I ended up with -- it will disturb my more anal friends with macs.
Just as a heads up, I had a magsafe brick that resembled the above one. I called apple (my macbook was bought refurbished and never had any applecare). They were EXTREMELY helpful, and OVERNIGHTED the adapter to me free of charge (including the return postage for the bad one). Timeline: I call at 4:00pm , at 9:00am the next morning I get my adapter. I think they've been failing at such a high rate that they fix it no questions asked now.
Same here!
THANK&nbsp;YOU!&nbsp; I've been looking for instructions for this end for months-- I&nbsp;KNEW it could be done! I'm going to try it this weekend.<br /> <br /> using hotglue to make a new casing is so helpful. I was thinking also, about moldable putty, and some fancy sculpting just for fun.<br />
also possible with sugru... google sugru ... it is a kind of resin!
epoxy putty is probably stronger and cheaper for this application. also sandable and paintable for more aesthetic repair.
You don't want stronger, actually, you want flexible-- so that your repair doesn't stress and break. <br><br>Would silicone sealant work as an electrical insulator?
For the plug itself strong is fine, furthermore it takes the stress point further away from the plug where repair is easier, but yes you can add strain relieve further down the line with store bought or just some simple layers of heat shrink tubing, perhaps splinted with some wire scraps.<br><br>Silicon sealant spread thin is too flexible to really provide any real strain relief, plus forming it is quite difficult. A layer of 1/4 inch bead thickness might work, but as I said forming it would be a pain. But if you do have some around you could possibly get some inside a large piece of heat shrink tubing, it would have to be quite large diameter to allow for 1/4&quot; of silicon and then shrink around it....but that might work. The main issue with silicon or caulk is that unless you can buy a small packet resealing a tube only works sometimes, so it is kind of wasteful...and messy. If you are going to use heat shrink anyways, might as wel just splint that with some scrap wire or some such material and be done with it.
About This Instructable
553,638views
168favorites
License:
More by Kactapuss:Budget Exacto Knife Metal Engraving Repair : Apple MacBook MagSafe Charger Power Cord Easy DIY Spray Paint Stash Can - 20 minute (or less!)
Add instructable to:
