3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair : Apple MacBook MagSafe Charger Power Cord
  • last photo ←
Apple really dropped the ball on the design of this charger. The wimpy wire used in the design is simply to weak to take any real stress, coiling, and yanks. Eventually the rubber sheath separates from the MagSafe connector or the Power-brick and the wire begin to fray or short, sometimes affecting charging and sometimes smoldering. If you use the tabs that fold out and allow you to wrap the cord around the brick you are probably reducing the life of you charger.
You may want to take your charger to apple straight away and see if they will replace this charger. I would cite reviews on the apple store website if they do not replace yours. If they do not replace it then start working on this instructable. Apple knows about this problem, but they have done noting to remedy it. This instructable is to provide hope for people who must forgo grocery shopping this week if they plan to buy a new charger. You can do it! Apple you should be ashamed of yourself....... show your loyal customers some mercy. You must be making a killing on these chargers.
In this Instructable I will cover opening the power brick case via brute force.
Preparing the Magsafe connector for soldering/ soldering.
Preparing the Power brick for soldering/ soldering.
Skills Required:
-Adventurous case cracking
-Exacto surgery
-Hot glue sculpting
-Soldering wires
Materials necessary:
1. Pliers
2. Screwdriver
3. Exacto Knife
(Skilled use of a dremel could save you a lot of time too!)
4. Electrical Tape
5. Soldering Iron
6. Hot glue gun
7. Love for going where you shouldn't.
Step 1Quick Work - Disassembly of Magsafe Connection
The MagSafe connector was already frayed free of the wire on my charger. But I did not have near enough wire to solder back onto. The aesthetically pleasing body of the connector needs to come off.
Out come the pliers (Slide lock in my case) to crush it off. Be careful not to damage the magnetic metal contact up front. We will still need to dig into this further to expose enough wire to solder to.
38 comments
Apr 4, 2012. 12:16 AMpvo van says:
Thank you so much
Feb 10, 2010. 10:46 AMwillstewart13 says:
I managed  to remove the "aesthetically pleasing body of the connector" without damage. If you place the metal part of the magsafe into a vice you can then use a small screwdriver to prise the plastic housing off.
I then used a scalpel (exacto knife) to carefully cut the translucent blob off to expose the internal circuit board to make soldering easier. This was done with a single cut to one of the short sides and then simply peel it off.
Once I unsoldered and soldered the wires back on the plastic housing (along with the rubber boot) just clicked back into place. However, i could not get the translucent blob back on.
Dec 27, 2011. 4:32 PMthefarns says:
I used Exactly the same method, except globbed hot glue on the circuit board and trimmed with a razor blade to allow the "Body Connector" to press back on. I then "corkscrewed" the spring from a pen onto the wire and wrapped the end where the wire (with spring) meets the "Body Connector" with electrical tape so that I had created a cavity which I then filled with hot glue.
Dec 27, 2011. 12:49 PMGstv.Inc says:
I have this charger but is brand new and i not need to fix but i whant share one thing that i made on my old hp charger.they broke the wire exacle the same way and i found a way to open that whit no damage at all , i put a knife betwen the two parts and tap on the back of the knife until a hear a snap from the glue i make this all around and open that leave no marks on that .
Nov 30, 2011. 5:08 PMmlee45 says:
My dog chewed through my charger, so i used dads spare one until this morning when he chewed through that one as well ahhhh. In both of the charges the break is mid wire. I have tried to reconnect the cables but this did not work. Any suggestions what am i doing wrong?
Nov 10, 2011. 11:32 PMdkollin says:
Apple just settled a class action lawsuit and is now replacing these for free: http://cnet.co/tl5p4W. I walked into the Mac store with my crappy one, they made me sign a document and then handed over a new one. Simple as that.
Nov 10, 2011. 11:25 PMdkollin says:
Nov 10, 2011. 11:19 PMdkollin says:
Oct 24, 2011. 12:17 AMinalak says:
I had no idea that other people did this or had this problem. My mom came to me and asked me to fix it so I said "I'll see what I can do," not knowing what the problem really was. I used nearly the same method but hers was only bad on the connector end. I ended up desoldering and resoldering directly to the connector without damaging the LEDs. Hot glue worked for me too. Awesome thing was that my mom had issues with her hard drive/data recovery later and needed to take it in. it wasn't covered by the protection plan at this point but the mac store guys were so impressed that both the charger and the leds still worked that they repaired everything free of charge. I guess being creative and cheap paid off eh?
Sep 30, 2011. 11:18 AMrrlemur says:
Thanks so much for this. You saved me, a grad student, $ needed for rent & ramen noodles. Eyebrow tweezers (the kind that open like scissors) came in handy. I also like the bandaged look I ended up with -- it will disturb my more anal friends with macs.
Sep 27, 2009. 12:51 PMslaytallica says:
Just as a heads up, I had a magsafe brick that resembled the above one. I called apple (my macbook was bought refurbished and never had any applecare). They were EXTREMELY helpful, and OVERNIGHTED the adapter to me free of charge (including the return postage for the bad one). Timeline: I call at 4:00pm , at 9:00am the next morning I get my adapter. I think they've been failing at such a high rate that they fix it no questions asked now.
Sep 16, 2011. 2:18 PMdjakobsson says:
Same here!
Nov 5, 2009. 9:46 PMprobablepossible says:
THANK YOU!  I've been looking for instructions for this end for months-- I KNEW it could be done! I'm going to try it this weekend.
using hotglue to make a new casing is so helpful. I was thinking also, about moldable putty, and some fancy sculpting just for fun.
Mar 26, 2011. 12:04 PMmballester says:
also possible with sugru... google sugru ... it is a kind of resin!
Jul 25, 2011. 3:59 PMwetnap says:
epoxy putty is probably stronger and cheaper for this application. also sandable and paintable for more aesthetic repair.
Jul 25, 2011. 4:59 PMprobablepossible says:
You don't want stronger, actually, you want flexible-- so that your repair doesn't stress and break.
Would silicone sealant work as an electrical insulator?
Jul 25, 2011. 5:43 PMwetnap says:
For the plug itself strong is fine, furthermore it takes the stress point further away from the plug where repair is easier, but yes you can add strain relieve further down the line with store bought or just some simple layers of heat shrink tubing, perhaps splinted with some wire scraps.
Silicon sealant spread thin is too flexible to really provide any real strain relief, plus forming it is quite difficult. A layer of 1/4 inch bead thickness might work, but as I said forming it would be a pain. But if you do have some around you could possibly get some inside a large piece of heat shrink tubing, it would have to be quite large diameter to allow for 1/4" of silicon and then shrink around it....but that might work. The main issue with silicon or caulk is that unless you can buy a small packet resealing a tube only works sometimes, so it is kind of wasteful...and messy. If you are going to use heat shrink anyways, might as wel just splint that with some scrap wire or some such material and be done with it.
Aug 14, 2011. 12:56 AMprobablepossible says:
This is the repair done with hot glue. This pic is about from march. Over times the hot glue surface went dull. Recently it actually cracked and peeled away, and I just now replaced it. I now have heavy nylon thread wrapped up the wire, under the hot glue. To make the old and new glue meld together was pretty easy-- held it over the gas burner and watched it get clear and glossy
I like the way it looks, on the whole-- reminds me of william gibsone novels.
Aug 14, 2011. 6:10 PMcat1010 says:
my Macbook Pro charger stopped working. I used a friends and it will not charge either. I called Apple and they are telling me that it will cost arounf 600.00 to fix this due this is connected to the mother board. does anyone have a fix for this???
Sep 6, 2011. 3:16 AMbarbecuesteve says:
If they're saying $600, you could probably fix it for $300 in parts and an afternoon of delicate work.
Sep 6, 2011. 3:15 AMbarbecuesteve says:
This isn't really the right forum to ask... try www.ifixit.com , they're Mac hardware guys.
Aug 7, 2011. 2:38 PMUElvd says:
Thanks a million! Oh I mean $80. DIY Rules. Thanks Kactapuss! Thanks Instructables! I pulled this off in an hour with very very very minimal wiring experience. Don't be afraid to try it! Take your time and remember....... Its already broken anyway. What do you have to lose trying? Don't let big business keep you down! Fight the man! You, I and we have the power to be self sufficient individuals within a greater community. Blessings!
Apr 11, 2011. 12:25 PMayoungblood84 says:
Very cool!!
Mar 25, 2011. 11:00 PMZoozoowow says:
Thanks for the tips. I was a little concerned when I began that I might get stumped by not having a soldering gun, but since the leads were still connected within the charger I just trimmed back the housing on the cable, twisted the ends of the broken wires, reconnected them, and tucked them into the housing before snapping it back together and applying some duct tape. It worked great, saved me $60, and seriously, who cares what it looks like. In fact, it's now bragging rights when friends come over and ask "what happened to your cable." to which I reply, "oh, that, it broke so I cracked it open, fixed it, and sealed it back up."
Thanks for the inspiration to break the corporate seal.
Feb 28, 2011. 1:31 PMpatadelacruz says:
Thanks so much! My problem was different in that the insulating sheath around the inside wire had been twisted apart over time causing a short about 3/8 inch behind the magnetic connection. Your post gave me the nuts to start hacking and sawing the thing down to where I could easily solder it back together.
Cheers.
Oct 24, 2010. 12:55 PMMisterSSL says:
BEFORE YOU DO ANY OF THIS: Make sure the problem isn't just in the MagSafe plug that goes into your Mac. Most problems are right there in that plug itself. Don't open the charger case if only the plug is bad. Your case will never look HALF as good after you take it apart as it did before.
If you DO decide to open the charger case, then assuming that you want to be able to reassemble it and have it work and be safe when you're done, there are some things you DO NOT want to do when opening the case. One of them is to destroy any or the plastic case around the power plug socket. Unfortunately, that's just what the big picture above does. That's NOT the place to start to open the case. Here are some alternatives:
1) Open the two flip-up doors, around which you wrap the low voltage wire, and then stick a pair of needle-nose pliers in the opening and use them to pry the two halves apart.
2) take a FINE saw (a jeweler's saw blade, a really fine hack saw, or a dremel rotary saw) and saw a very shallow distance (no more than 1/16th of an inch or 2 mm) along the plastic seam between the two halves of the case, along the top and bottom edges of the case (as shown in the picture above). Those are the edges that are glued together.
3) Take a very sharp wood chisel (1/2 or 1 inch wide), and place it along the top seam, and hit it twice with a hammer, then move it down and repeat. Do this along the top and bottom.
Oct 2, 2010. 7:19 PMlukeyj15 says:
Use sugru to fix the connector once you have fixed the connection.
Jul 14, 2010. 11:44 AMdault2 says:
great DIY. had a hard time finding instructions on the connection end of the cable. Fixed one a friend gave to me so now I have 2. Thanks!
Jul 4, 2010. 12:12 AMvvwwuu says:
Hi,I have connected the wires as shown in the picture no 4 and I tried to connect to my macbook before I start to solder it down.However the light shows green instead of red which indicates that it's not charging.Does it mean that I have made a mistake in some steps?Please advise.Thanks for the instructions.
Jun 10, 2010. 2:59 PMMarkushka says:
Thank you, i just did this and now its charging again! great DIY, and saved me some money :)
Apr 7, 2010. 1:25 PMaeal121 says:
 wow. this is great. I feel extremely accomplished about the fact that my computer is now charging with a newly-fixed charger!
So there was no way I was gonna buy another stupid macbook charger. My first one frayed like this so I bought a second...which also frayed. I'm glad I was able to fix this.
Shame shame, Apple. Why do you make crappy chargers?!
Apr 7, 2010. 1:08 PMaeal121 says:
 this step is SUPER tedious! Be careful! It took me forever and one sliced finger to do it.
Mar 27, 2010. 2:32 PMabelincoln says:
This is a fantastic fix it.  Thanks for being bold and trying it out.  One thing that helps with the aesthetics (as if that matters at this point) is to use white electrical tape intead of black.  It works and looks a lot nicer than wrapping your brick with black tape.
Feb 15, 2010. 11:04 PMimark77 says:
I had this problem with my old iBook charger but unfortunately I figured it out before you.
this is a well-done instructables though my only problem now is I have three chargers for a iBook with the dreaded video chip problem and now all it does is sit on my desk as my personal Web server with three power cords On the side for in case of emergency.
oh PS by the way the core problem goes back to the iBook chargers, because most of my failures were with the cabling separating and fraying to the point where it wouldn't be connecting any more while the main positive cable was still in relatively good shape. and at least one incident was with the breaking of the tip which is a 2.5 mm phone plug in a metal shield and are not that easy to come by but the good news is that I had one from a previous adapter that completely fried ( mysteriously stopped working a few days later ) for some reason involving a cat in a poll a few miles down the road and a short power outage.
Feb 14, 2010. 8:39 PMjoe_photo says:
Hi I Recently fixed my charger, Thanks for the tips..
But  may  when removing the rubber that is used to hold the extra bit of wire instead of doing soldering iron melting and exacto surgery to remove it simply use pliers or cut it slightly down the side and can remove it like the hard outer cover even easier then tthe outer cover,
worth taking the time in the end..Save 100+
Feb 14, 2010. 8:33 PMMrNagrom says:
i figure you go through one like once every say 2 years.  i just buy a new one.
good instructable but i don't think i could deal with that glommed up charger hanging off my computer.
Feb 14, 2010. 11:15 AMManifoldSky says:
 This is not really a case of "form over function" design. This is a case of bad design, and bad user practice. First, form over function implies that the form itself interferes with function, and the form won out. The power adaptor could have been made to look all but identical, and still not have most of these issues.
More importantly even with a better made charger with more robust strain relief, this type of damage occurs anyway, due to cord winding (though it is exacerbated by the square form of the adaptor head.) One should never wrap ANY length of cable over and over again. This puts significant, repeated stress on one side of cable, and each coil stretches the one side longer and longer as it travels the outside diameter of the circle, causing it to eventually fail. This is especially common with audio patch cables. Instead, one should "counter wrap." First wrap one coil overhand, so the free cable lies on top of the loops, then wrap the next coil underhand, so the free end comes out from under the previous coils. This forms a "mobius stip" that causes the strained side to reverse every coil. If one insists on using the fold out winding wings on the charger, one can arrive at the same effect by making a figure 8 after every coil, thus reversing the direction.
To increase the longevity of the cable, a little hot glue at both ends acts as an additional strain relief.
Jan 3, 2010. 6:35 PMbluecamel says:
Thanks so much for this!  It gave me the confidence to finally tear into and fix the two old adapters that I've had die like this.
A tip on breaking into the power brick.  Use a knife to cut along the seam.  Be careful to not go too deep or you'll cut into the components.  If you're cautious, you can cut along the entire seam, gently prying the case apart along the way.  This way is actually easier then just prying the case apart and you'll have two clean case sides for reassembly.  I ended up just taping mine back together, but you could easily glue the case back together and you'd hardly notice that it was ever opened.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Kactapuss
