Step 4Repair on the Power Brick Side
I chose to cut, strip, clean, and tin the existing wires on both sides of the joint.
Tape or use heat shrink tubing on this joint. Remember not to leave too much extra wire around the joint because we are going to stuff it all into the case before closing it up.
You may opt to super glue epoxy your case shut. I just snapped it back as well as possible and gave it a healthy dose of electrical tape in case I ever need to check on my solder joints. I also tightly wrapped about and 1.5" of wire to the body of the brick to act as a strain relief.
Add Comment
