Step 7Tweak the driver settings
With the pen selected, choose the mapping tab. For "Screen Area", choose "Portion." You'll need to map out where your sensor ended up. The easiest way I found was to click the "Click to define screen area" button and use the stylus to find the top-left-most and bottom-right-most points the pen could get to. With a little pixel-nudging (editing the coordinate values in the boxes) after that, I got a good matchup. Each time you change a value, it will feel like you're getting an immediate change in the mapping, but it's not actually doing it terribly accurately until you click OK after you've made a change.
You're all set! Be sure to check out Ink Well.
FUTURE: I'd like to snip off the wire close to the hole and solder on a female mini USB port, but for now the laptop looks like a member of the BORG. But it works!
Add Comment
