3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MacBook/iMac Rack Hack
How to get all the benefits of an iMac/All-in-one PC from your Macbook/laptop without sacrificing portability or desktop space.
I basically modified a wire mesh office file holder to mount on back of a 22in. LCD to hold my Macbook for desktop use, conveniently hiding the computer while providing easy port access.
You will need:
- a laptop
- an LCD monitor
- external keyboard and mouse
- an office file rack/holder
- 2-4 screws with washers
- pliers, perhaps a metal file
- foam (optional)
mattlumpkin@gmail.com
http://mattlumpkin.blogspot.com
Step 1Select an LCD
Select an LCD
You need an LCD that is bigger than the laptop you want to use and that has the mounting holes available on the back. Some of Acer and Dell's models mount their stands in these holes. This won't work for my design.
I chose the Asus VK22H (about $200 from Newegg.com). There are lots of LCD's that work for this and and only a few won't. The easiest method is to look at the pics on Newegg or Amazon to confirm available screw holes and room above the stand.
38 comments
Apr 12, 2010. 6:51 PMkurt.haines says:
 Are you able to provide a profile photo of the your revised laptop position in the stand?
Going to be doing this myself to watch TV in my room using a USB TV Tuner and external speakers and just want to make sure I get the orientation right as the TV Tuner can sometimes make the fans run a bit.
Apr 13, 2010. 4:24 PMkurt.haines says:
 Awesome.  Thanks for the iFixit idea.  Going to open up the Macbook and checkout the fan situation and give it a clean.  Might as well clean the whole laptop out, I think it needs it!
Will let you know how it goes.
Mar 14, 2010. 5:50 PMlimpport says:
 So I've figured out that the Macbook HAS to be plugged in for this to work.
I take the battery out when I have it plugged into the monitor, so I have to take a long piece of tape, wrap it once around the power cord near the plug, and tape it plugged in.
Dec 3, 2009. 2:36 PMlimpport says:
 Nice bookshelf!
Dec 13, 2009. 12:54 PMYerboogieman says:
Shelf? All I see is Books!
Jan 10, 2010. 7:18 PMYerboogieman says:
I know, I was kidding.
Jan 7, 2010. 9:58 PMabinadab12 says:
where can i get or how do i look up where to get that mesh file rack. just came from office depot only found a plastic one.
Dec 16, 2009. 10:51 PMGenetastic says:
I'm not sure where vents are located on an iBook, but when the laptop lid is closed, is heat an issue when running the machine?
Feb 26, 2009. 10:09 PMsypage says:
Clever idea, but just one suggestion: Why couldn't you rotate the laptop 180 degrees in the stand so you could access the optical drive from the top? Seems like that would work with my MacBook Pro, as there are no ports on the rear edge. I'm not sure about the MacBook's port configuration, as I don't have one.
Dec 13, 2009. 5:06 PMlimpport says:
 I was thinking about what sypage said.  If you cut out in the bottom of the basket just enough to access the ports, the optical drive could stick upwards.  This also means that both sides of the rack can stay on, keeping it stronger.
And if your keyboard has quick keys you can set, just make one of them the eject button.   Apple keyboards are basically the exact same as the ones on their laptops, so they have the eject/volume/brightness/etc.
Dec 12, 2009. 8:46 PMYerboogieman says:
Sweet. I just got a new Asus widescreen monitor a few months ago. Good deal.
Nov 26, 2009. 2:03 PMSolifluktion says:
Great idea. Gotta try this with my Acer Aspire One (although I still habe a "real" Computer). btw I have the 24inch Version of your Display ;)
Oct 29, 2009. 7:23 PMbernardomed says:
Great Idea.
But using Snow Leopard (10.6.1) I had to use InsomniaX to keep my MacBook Pro from sleep.
Man I must get me a 30" monitor. Or at least a 24". :)
Oct 27, 2008. 8:10 AMgmjhowe says:
Nice work, though, let me ask, do you just pull out the laptop open it and turn it on normally, or have you found some other way to do it? i want to know, as im thinking of running my laptop on its side, to give me more room!
Feb 27, 2009. 6:51 AMflio191 says:
Use InsomniaX it keeps your mac on even when it's closed.
Sep 13, 2009. 11:28 PMfnnw7777 says:
if you have a wireless keybored or mouse you just move your mouse or randomly type and your macbook should wake up if you have your display is connected
Feb 27, 2009. 11:37 AMflio191 says:
The only problem, of course, is that it will heat up your computer because it's designed to dispel heat while open. But if you install something like smcControl or some other fan controlling application, and you run that while running insomniaX, im sure it would be fine. Also attaching the USB fan would be good especially for this.
Feb 28, 2009. 6:28 PMflio191 says:
oh, cool, good to hear. yeah, that makes sense, especially because some of the heat would be dispersed through the metal basket.
Oct 27, 2008. 9:47 AMgmjhowe says:
haha, i get you with the not turning it on. Well, when i looked into the option previously, there was no solution. I was hoping that you had found a solution! ah well, i will have to give it some more thought! Another idea, it might be worth adding a usb hub and fan to your rig? More usb ports are always good, and the macbooks work a bit faster when cooled externally. Plus with the extra heat being kicked out the back of the monitor!
Oct 27, 2008. 10:29 AMgmjhowe says:
indeed, alot of pc laptops sound like v8 engines compared to the macbook. however, it might be worth looking into some of the 'gaming' pc fans, that are actually very quiet. If and when i take to have the macbook in its vertical position, i intend to rig up at least 1 or two fans.
Feb 26, 2009. 11:05 PMVanTurenhout says:
Nice, but how about switching the laptop on? I don't know how it works with an iBook, but with my Lenovo I have to open the lid to switch it on. So I have to take it out, swtich it on and put it back...hmmm
Jul 29, 2009. 12:37 PMmynameinc says:
If you were using Linux (or any *nix) you could, theoretically, go 180 days without shutting down or rebooting. If you want Windows (for what reason, I'll never know), you could take a coat hanger, and bend it properly so a shift of it would depress the power button.
Apr 22, 2009. 6:07 AMbradmurray says:
Why wouldn't you just open the laptop and position the basket such that the laptop screen is visible above the monitor? I'm always looking for extra screen space and this seems like the perfect place to put it.
Feb 27, 2009. 7:00 PMwatchurmouthyoungman says:
what if your laptop is REALLY heavy? and old? likes 5 pounds... wont the monitor tip backwards? :(
Feb 27, 2009. 10:34 AMapmc5d says:
How do you get the lap top not to go to sleep when you close it.... even when it is hooked to the VGA cable i can not get my mac to not go into sleep mode?
Feb 27, 2009. 10:37 AMpodginater says:
That's Crazy. Great idea. Couldn't you ,if you had the latest macbook, just cut a slim line in the mesh to make the superdrive accesible.
Feb 27, 2009. 1:52 AMPunkguyta says:
Yeah? You should see what I did to my ibook :D
Feb 26, 2009. 4:05 PMneuralstatic says:
if only the MBP had all the ports on one side like that, i'd do it in a minute. a little less elegant if the power is on one side and the monitor cable on the opposite etc.
Jan 11, 2009. 1:53 PMphant0m_sp00f3ra says:
Hey mate this a great idea!!! i really gotta do it with a 30" display :P (gotta break into the neighbor)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mattlumpkin
Grad student in theology in Pasadena, CA into photography, tech, music and integrating them all with my studies.
