3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MacBook/iMac Rack Hack
Step 4Insert Laptop: Enjoy!
Here's the finished product: desktop functionality when you're at home and easy portability when you need to go.
Revisions:
I angled the foam to pitch the laptop forward, however, I've since found that this isn't ideal for dissipating heat. If you lean the macbook all the way back but leave an inch or so clearance between it and the wall, it runs cooler than sitting on the desk.
Again, if I had it to do again I would leave the frame on the port side and trim out the mesh. Also the optical drive isn't accessible under this configuration without lifting the macbook up slightly. However, this happens so rarely that it's not been work developing a better design.
Enjoy I'd love to hear/see how you implement/modify this idea.
mattlumpkin@gmail.com
http://mattlumpkin.blogspot.com
12 comments
Apr 12, 2010. 6:51 PMkurt.haines says:
 Are you able to provide a profile photo of the your revised laptop position in the stand?
Going to be doing this myself to watch TV in my room using a USB TV Tuner and external speakers and just want to make sure I get the orientation right as the TV Tuner can sometimes make the fans run a bit.
Apr 13, 2010. 4:24 PMkurt.haines says:
 Awesome.  Thanks for the iFixit idea.  Going to open up the Macbook and checkout the fan situation and give it a clean.  Might as well clean the whole laptop out, I think it needs it!
Will let you know how it goes.
Dec 3, 2009. 2:36 PMlimpport says:
 Nice bookshelf!
Dec 13, 2009. 12:54 PMYerboogieman says:
Shelf? All I see is Books!
Jan 10, 2010. 7:18 PMYerboogieman says:
I know, I was kidding.
Dec 16, 2009. 10:51 PMGenetastic says:
I'm not sure where vents are located on an iBook, but when the laptop lid is closed, is heat an issue when running the machine?
Feb 26, 2009. 10:09 PMsypage says:
Clever idea, but just one suggestion: Why couldn't you rotate the laptop 180 degrees in the stand so you could access the optical drive from the top? Seems like that would work with my MacBook Pro, as there are no ports on the rear edge. I'm not sure about the MacBook's port configuration, as I don't have one.
Dec 13, 2009. 5:06 PMlimpport says:
 I was thinking about what sypage said.  If you cut out in the bottom of the basket just enough to access the ports, the optical drive could stick upwards.  This also means that both sides of the rack can stay on, keeping it stronger.
And if your keyboard has quick keys you can set, just make one of them the eject button.   Apple keyboards are basically the exact same as the ones on their laptops, so they have the eject/volume/brightness/etc.
Feb 26, 2009. 11:05 PMVanTurenhout says:
Nice, but how about switching the laptop on? I don't know how it works with an iBook, but with my Lenovo I have to open the lid to switch it on. So I have to take it out, swtich it on and put it back...hmmm
Jul 29, 2009. 12:37 PMmynameinc says:
If you were using Linux (or any *nix) you could, theoretically, go 180 days without shutting down or rebooting. If you want Windows (for what reason, I'll never know), you could take a coat hanger, and bend it properly so a shift of it would depress the power button.
Feb 27, 2009. 10:34 AMapmc5d says:
How do you get the lap top not to go to sleep when you close it.... even when it is hooked to the VGA cable i can not get my mac to not go into sleep mode?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mattlumpkin
Grad student in theology in Pasadena, CA into photography, tech, music and integrating them all with my studies.
