3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Macgyver Phone Charging
Every once in a while you get the problem of your cell phone running out of batteries just when you haven't got a charger at hand.
This afternoon it happened to me,.... Damn empty battery and no charger for miles... At least that I know of.
So what do you do ? Build your own, in,.... 1 minute.
Step 1Find the pinout of your phone
This instructable will only work with some phones, because you can't imitate the most plugs that are used to charger mobile phones, but with my Sony Ericsson it works fine because of the way the phone is charged.
To find the pinout of your phone, you could use Google, or use ( the one I used, with help of google Pinouts ). Hit Ctrl + F and go look for you phone pinout. If you can't find it, you'll have a problem and won't be able to continue, but you usually will.
My phone has a 'standard ?' Sony Ericsson plug so it was easy to find. I used the image below, disgarding the Datacable part,... which it think can be pretty usefull :).
11 comments
Oct 19, 2007. 9:16 AMDWFMBA says:
or put the battery in a fridge for a few minutes... that will buy you some talktime too
Sep 22, 2008. 10:45 AMbaneat says:
I think you need to warm it, not cool it. Who can build this thing in a minute!??
Jun 20, 2009. 11:02 AMFieldownage says:
Warming batteries decreaces their "life-time" but cooling their "standby-time"
Jun 23, 2008. 2:22 PMandrew13 says:
whats mcgyver?
May 29, 2009. 10:23 PMtoogers says:
a guy on an old 90's tv show. he can make/do anything with common hose hold matearials. like once, he fixed a crack in a tank of sulfuric acid with choclate.
Aug 13, 2008. 6:27 PMhfdjgl says:
Mcgyver was a guy on a tv show that could make anything out of what he had. Like he could make an airplane out of anything he could get his hands on.
Nov 30, 2006. 9:57 PMpojken says:
If you're in a bind and only need a minute or two, try rubbing the battery with your hands until it's relatively warm. A woman I told this to actually used that hint in an emergency and was able to call her daughter. Not an instructable, but a helpful hint.
Nov 22, 2006. 7:48 AMGoover says:
Cool, you are lucky that the voltage regulator is smoked, and not your phone. (Bolletje Pepernoten! van AH! Stomme Nederlander :P)
Nov 21, 2006. 11:45 PMcurlyfry562 says:
That project in the background looks like a bunch of flash circuit capacitors wired up, I am working on a similar project myself
Nov 21, 2006. 1:13 PMRaisedByRobots says:
Cool, now if I could just wire it up to use a longer lasting battery...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MrGAmba
