3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Machine Your Own Guitar
Step 13Assembly and Wiring
Assembly and Wiring
To wire the guitar, you will have to pull the pickup wires through that long hole in the body.  To do this, tie a piece of string to a long thin screwdriver, or a metal rod, and push it all the way through from the output jack hole to the pickup pocket.  Once it comes out, untie it and tie each pickup wire to it.  Be sure to route the neck pickup wire through its own hole first!  Pull the wires through the hole and into the back cavity.  Now you can screw the pickups in place so they don't fall out and pull their wires back.
Place the potentiometers in their holes and attach the washer and nut on the front side.  Tighten them in place, and attach the knobs via their set screws.
Wire up the circuit as per the diagram or schematic below.  To wire the 1/4" jack, mount the jack in the jack plate, then solder wires to the two connectors.  Then, push the wires through into the back cavity.  Then solder them in place.  Put electrical tape on exposed wires so they don't short each other out.
The tail piece and bridge may need to be wood glued or epoxied into their places.  Hit them lightly with a mallet to make sure they're seated fully.
Attach the neck and tighten the neck screw firmly, install the bridge and tail piece, and string it up.  Test with an amplifier to see if the wiring is correct, and then screw shut the back plate.
You're done!
3 comments
Jan 2, 2011. 9:55 AMhohum says:
sorry to be the dumb one,,,,, but, are all the black wires connected together?
very nice looking guitar, be proud for your undertaking, it was a lot of work
Aug 15, 2010. 10:40 AMslappy1eye says:
First let me say, not too bad for your 1st guitar! I bet your next one will be pretty awesome! To make a custom guitar all you have to do to "size up" the project, the placement of the bridge has to be equal to the distance from the center of the nut to the top of the back of the 12th fret as the distance from the center of the bridge post from the back of the top of the 12th fret. http://www.stewmac.com/freeinfo/Building,_general/Assembly/i-4003/i-4003_3.html StewMac has excellent builders guide information http://www.stewmac.com/freeinfo/Building,_general/Assembly/i-4003.html
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
122
Author:mattthegamer463
