loading
Step 14: Mark & Drill Screw Hole Locations
Determine locations for three equidisdant screw holes on one bearing plate with a protractor. Place a pencil mark every 120 deg and 1/4" in from the circumference. Use this disc as a template to locate holes on the remaining bearing plate as well as on the inner and outer end plates. Making sure shaft holes of each disc serve as the common center. Drill holes where marked to accommodate #6-32 machine screws, flat washers and wing nuts (later replaced by hex nuts in Step 21) .
At this point, glue one set of inner plates to one set of outer plates. Repeat this procedure with the remaining set of plates. Use the machine screws to secure these assemblies until dry. Do not glue retaining rings to plate assemblies!
How is this better than blowing on a propeller to turn a shaft?
The results would be identical. In both instances the shaft turns. However, the TT contains no impeller blades to bend or break. Also, discs are easier to fabricate from cardboard -- just use a compass & scissors :D.
BETTERTHAN THE BEST <br>
That's the motto of the Royal Newfoundland Regiment!
Thanks for your support!
Hey dude may i ask something? what is the initial length of this? i made a replica of your tubine in (much cheaper version) so, can you give me like some formula? ex:<br><br>Wind speed + blade diameters = speed of fan? you know something like that. Like i said, mine is a bit cheaper so could you go through the roll size and length and this sort of stuff?
Try this web site to calculate turbine output. There's a downloadable excel app: <br>http://www.stanford.edu/~hydrobay/lookat/tt.html#sect-6-c. <br>Here are the dims for the turbine: <br> <br>Tube length: 90 mm <br>I.D. 87 mm <br>Disk width: 3 mm <br>Disk dia: 84 mm <br>Spacing: 3 mm
the site must hate me cause it said your price $99 as though im the only onw having to pay that price , if thats what you paid then your insane<br>
Don't worry dude i am making a &quot;cheap version&quot; of this one. Well pray that mine works &quot;i am currently using a bond paper puncher, a scissors, an illustration board, a compass, a sandpaper and some skewer stick. OK pray that i got motivations or Tesla's deity bless me.
wow .. that's amazing ..<br>can tesla use water for the fluida ???<br>thanks..
Try applying several coats of waterproofing spray to all cardboard parts first.
Text is way too glitched for me<br>
Unfortunately, the glitched pp could not be repaired w/o re-doing the entire i'ble...
Do you notice each time it text glitches you are typing the word &quot;won't&quot;?
Reminds me of my English teacher in high school who didn't accept essays with contractions!
D&eacute;penser de l'&eacute;nergie pour faire tourner un arbre, c'est ce que font tous les moteurs, quel est l'avantage de ce dispositif?<br><br>Spend energy to run a shaft, that is what do all the engines, what is the advantage of this device?
A Tesla turbine w/a large enough air scoop could generate power from the wind.
Uh... still getting a <em><strong>lot</strong></em> of: &Atilde;�&iuml;&iquest;&frac12;&Atilde;&macr;&Acirc;&iquest;&Acirc;&frac12;&Atilde;�&iuml;&iquest;&frac12; <strong><em>instead</em></strong> of readable text...<br> <br> Otherwise, seems [?] pretty cool.
A glitch w/the text editor...
vid of it running? :)
Just posted a vid here: http://www.youtube.com/watch?v=_Wq8KLpnqRk
Can't be read in Internet Explorer 9 either!
Edit command is frozen; still working on fixing problem...
not all of your characters are readable in my browser (chrome). would you consider using simple text to make your instructable readable by chrome users?
Not working in Safari either.
i have the same problem
The rogue character is just an apostrophe. Something has happened with the editor here to make it spit out a million of them!
Thanks for the feedback about the characters. It seems my page may have been hacked on Fri evening when the malicious character string first appeared. The &quot;edit&quot; command is now frozen, so the string can't be deleted for the moment. Maybe there's a &quot;Geek Squad&quot; at Instructables to fix these problems?
same here
Doesn't work in Firefox or Safari either.
My browser Firefox cant read a couple things!
deffo 5* my friend....well done.
Good job on making one out of cardboard. My machine shop team in college made a prototype out of cardboard first before tackling the project in metal. It allowed us to work out the kinks. I just gotta say that we won 1st place in the WESTEC2004 Manufacturing contest in Los Angeles, CA. with a 4inch diameter Tesla turbine.
You rightly deserve to know about this little gem, the Fonly Lathe:<br>https://sites.google.com/site/buildyourstuff/thefonlylathe
Thanks, as always , for your interest!
We Portuguese-speaking guys gotta stick together...
On my Blog, now, a Link to your Instructable: http://faz-voce-mesmo.blogspot.com/2011/10/tesla-tesla.html
AWESOME WORK!<br><br>Thanks for sharing.
About This Instructable
56,526views
110favorites
License:
More by brazilero2008:Finishing Details for the Electrostatic Turbine Improved Electrostatic Turbine Made from Recyclables Simple TC Powered Plasma Globe
Add instructable to:
