Remove these ads by
Signing UpStep 1Gather materials
Alternatively, you could use 316L for the bar. I've made quite a bit of stuff from titanium and in small sizes it's pretty much like working 316- I don't see much reason not to use the titanium and some people may have reactions to the small amount of nickel in 316.
I love using recycled materials for projects. I'm always grabbing scrap metal out of trash and my basement is, well, let's say it's full. This is one place where scrap materials are a really bad idea. For piercing jewelry I would only use 316L stainless, titanium, or gold. Use new materials from sources that know their stock. 'Stainless steel' rod from the hobby store or home center won't cut it, and is probably more expensive than buying good stock from a metal supplier. Anything else is risking nasty metal reactions and infections. The right stuff is not very expensive- all these materials should run under $10 and give enough for 5 or 10 pieces of jewelry.
Everton Watson
evertonwatson@gmail.com
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=37861
http://www.instructables.com/group/bodymods/
Link
What grade of Ti are you using. Commercially pure?
As for your lathe work a couple things. You may get better performance from HSS bits, Cobalt even better. You can get a much sharper edge on HSS than carbide. Especially with the TNMG inserts you are using. There is also a company that offers HSS and cobalt TNMG inserts that should work with your holders. It looks like you are using TNMG21.51?
Second is work holding. Try to get a collet chuck of you can. Better runout and repeatability especially when using small barstock like this. Littlemachineshop has some setups for your lathe.
Third. Either use a dead center or follow rest when turning long thin materials. This will reduce the spring cut you need to take. A follow rest is available for your lathe.
Fourth: Center drill are for making the pilot hole for centers, live or dead. Use a spotting drill with a split point to spot before drilling. They will not wander like a center drill will. Alternatively use a split point screw machine length drill and drill in one go.
Fifth. Use an actual counterbore bit to counterbore. They are available in many different sizes and pilot sizes.
Sixth. Tapping, look up the drill size for 50% threads. You shoudnt need anything more than that and this will reduce tap breakage. Also give the form taps a try.
Dont set youself on a Hardinge. There are a lot of machines as good or better than a Hardinge and many times cheaper. A Monarch 10EE is a good choice. Better runout than a Hardinge from the factory and weighs more as well (Mine is about 3500LBS) I used to have one of the lathes like yours. Great little machine. But the lower belt cover on my machine weighs as much as your lathe. More mass = Less Vibration = Better Finish = Happy Operator
http://www.precisiontwistdrill.com/techhelp/help_pages/thread_forming_prod_taps.asp
Also you might want to get a tapping guide, they are spring loaded and inexpensive.
http://www.cartertools.com/fmpdtg.html#hftg
(the link is to my commercial page showing the use of a product I sell, but you can get them from any metalworking supply house, like MSC or Enco, in the interests of non-commercial-ness)
http://flexarminc.com/flex1.htm
Too expensive for me though...I do use a tapping head an awful lot anymore, and I have just strated playing with threadmilling on the CNC...
I use my Taig tailstock for holding taps - it has a lever arm instead of a screw so it's really easy, but I know what you mean about feel with the tailstock, if you can get into that 1/4 turn at a time groove...
On the body jewelry thing I had a nice gig for a while making tiny nose studs(turning 14ga. down to 18ga and making a ball) for a local shop, and once had to modify a 2ga.(!) hoop that was causing some prince-albert-related discomfort - I made sure that thing was autoclaved 1000 times before consenting to work on it!
And yes, you can never have too many tools...
