3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Machining titanium and stainless steel jewelry
  • last photo ←
Jewelry for body piercing is expensive and can be hard to find, particularly if you need an unusual or large size. I go through the steps of machining a barbell style piece from scratch. This project includes many operations typical of small scale machining on a lathe including facing, turning down, drilling, tapping, and polishing.
Step 1Gather materials
Gather materials
The first step, as in most projects, is to track down all the materials you'll need. For this barbell, we'll use titanium and 316L stainless steel. The titanium bar stock is 1/8 inch (3.2mm) diameter, and we'll only use a small amount of it. The screws are 18/8 stainless- still corrosion resistant, but stronger than 300 series. The balls are 316L ball bearings. All of this is pretty easy to find online. smallparts.com and onlinemetals.com are good sources.
Alternatively, you could use 316L for the bar. I've made quite a bit of stuff from titanium and in small sizes it's pretty much like working 316- I don't see much reason not to use the titanium and some people may have reactions to the small amount of nickel in 316.
I love using recycled materials for projects. I'm always grabbing scrap metal out of trash and my basement is, well, let's say it's full. This is one place where scrap materials are a really bad idea. For piercing jewelry I would only use 316L stainless, titanium, or gold. Use new materials from sources that know their stock. 'Stainless steel' rod from the hobby store or home center won't cut it, and is probably more expensive than buying good stock from a metal supplier. Anything else is risking nasty metal reactions and infections. The right stuff is not very expensive- all these materials should run under $10 and give enough for 5 or 10 pieces of jewelry.
30 comments
Feb 17, 2012. 7:57 PMblack hole says:
Where do you get your titanium? And at what price?
Jul 1, 2006. 5:21 PM_soapy_ says:
As an idea, you can machine the bar to any size you want, so why not make the balls first, pair them off, and then make the bars to the right size for the holes. That way you won't have nay issues with the countersinks being the wrong size. Nice instructable. :-)
Feb 26, 2011. 9:43 PMeverton9698 says:
Hello I was referred to you by an asscoiate . My name is everton and I dont small time acting and promoting. I have a custom piece that need to be made that I belive you can make. I had a gentleman in texas that use to make custom spikes for me. I have dermal implants in my head that allow me to screw a metal spiked mohawk in over that last year of going to events and getting drunk I have lost a few of them. I can send you one to use as a example and or email you pictures . They ones I have now are 6-8 guage -80 pitch . If you can help me out this would go alone way and I will compsensate you. If you have someone you can refer me to please do so thanks
Everton Watson
evertonwatson@gmail.com
Feb 14, 2007. 7:16 AMironsmiter says:
Bump! just kidding. An actual tip. Instead of an appearent counterbore(or was this an illusion o fthe photo?) use an actual countersink.(I'd use the center drill again, for a hole that small) When machining the bar, make it a few thou over the size of the outside o the countersink. Put a taper on the end of the bar that matches your counter sink. If your tools are sharp, and your eye keen, this should give a "seamless" joint, as long as the tapped hole in the shaft is deeper than the threads on the post.
Feb 28, 2009. 1:07 PMblacknkhak says:
would you make an instructable about making captured bead rings?
Mar 21, 2010. 3:47 PMsrabel10 says:
captive* lol
Apr 1, 2009. 10:12 AMclark says:
i second that!
Apr 9, 2009. 4:28 PM316LVM says:
Awesome job I've been making body jewelry for 5 years (nothing threaded) mostly just custom bends and other designs..this is a good instruction on how to make a barbell! thank you so much for posting this!
Jan 23, 2007. 10:33 PMxenobiologista says:
What are those things that look like tubes of pigment on the bench top?
Feb 10, 2009. 3:43 PMjzoch says:
I think those are T handle hex keys like these:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=37861
May 17, 2008. 4:54 PMmasterochicken says:
Jul 31, 2007. 10:15 PMTravisHaynes says:
Did you know that titanium can actually be cut with water?
Link
Jul 16, 2007. 7:57 PMmacona says:
316L is available at most weld shops as tig filler rod. Standard sizes are .035, 3/32, and 1/8. Thicker can be ordered.
What grade of Ti are you using. Commercially pure?
As for your lathe work a couple things. You may get better performance from HSS bits, Cobalt even better. You can get a much sharper edge on HSS than carbide. Especially with the TNMG inserts you are using. There is also a company that offers HSS and cobalt TNMG inserts that should work with your holders. It looks like you are using TNMG21.51?
Second is work holding. Try to get a collet chuck of you can. Better runout and repeatability especially when using small barstock like this. Littlemachineshop has some setups for your lathe.
Third. Either use a dead center or follow rest when turning long thin materials. This will reduce the spring cut you need to take. A follow rest is available for your lathe.
Fourth: Center drill are for making the pilot hole for centers, live or dead. Use a spotting drill with a split point to spot before drilling. They will not wander like a center drill will. Alternatively use a split point screw machine length drill and drill in one go.
Fifth. Use an actual counterbore bit to counterbore. They are available in many different sizes and pilot sizes.
Sixth. Tapping, look up the drill size for 50% threads. You shoudnt need anything more than that and this will reduce tap breakage. Also give the form taps a try.
Dont set youself on a Hardinge. There are a lot of machines as good or better than a Hardinge and many times cheaper. A Monarch 10EE is a good choice. Better runout than a Hardinge from the factory and weighs more as well (Mine is about 3500LBS) I used to have one of the lathes like yours. Great little machine. But the lower belt cover on my machine weighs as much as your lathe. More mass = Less Vibration = Better Finish = Happy Operator
Jul 6, 2006. 9:08 PMokto says:
Nice job. Any tips on creating curved-bar jewelry? I'd like to make some custom stuff for my eyebrow.
Jul 2, 2006. 1:19 AMmalachite2501 says:
thats awsome i wish i had all those tools, iv custom mad retainers before and debarbed and polished hooks for suspension but thats just sweet
Jul 6, 2006. 9:12 PMokto says:
What did you make the retainers out of (and how)? I'd rather make my own than pay for 'em.
Jul 1, 2006. 9:26 PMnatemc says:
You should autoclave any jewelry before you stick them in a human, especially if your putting them in a freshly pierced hole as jewelry of this type often is.
Jul 3, 2006. 6:55 AMCrowyhead says:
Eh, it's not really necessary to autoclave if it's going into an established, healed peircing -- simply cleaning the jewelry with alcohol is usually sufficient. For fresh piercings, it depends on the piercing parlor, but they'll often autoclave custom jewelry for you, provided it meets their quality standards.
Jul 1, 2006. 3:55 PMTGM says:
What make/model of lathe are you using ? Curiosity . . .
Jul 2, 2006. 1:18 PMTGM says:
Oh I know you can do it on just about any lathe. However, I'm the market for a small home use one like this.
Jul 1, 2006. 2:12 PMBeanwaur says:
very nice! its a shame you cant view each step individually... you have to view all steps
Jul 1, 2006. 5:19 PM_soapy_ says:
Eh? Just click on the step you want to view alone, and it will reload just that step. Up at the top, where it says "Steps".
Jul 2, 2006. 9:29 AMjtobako says:
how about reducing the file size?
Jul 1, 2006. 11:22 PMkrusty says:
"Drill your balls" LOL
Jul 1, 2006. 3:20 PMcartertools says:
You might look into using form (or fluteless) taps, they forge/form the thread instead of cutting it, no flutes means stronger tap and less chance of breakage.
http://www.precisiontwistdrill.com/techhelp/help_pages/thread_forming_prod_taps.asp
Also you might want to get a tapping guide, they are spring loaded and inexpensive.
http://www.cartertools.com/fmpdtg.html#hftg
(the link is to my commercial page showing the use of a product I sell, but you can get them from any metalworking supply house, like MSC or Enco, in the interests of non-commercial-ness)
Jul 1, 2006. 9:05 PMcartertools says:
You use a larger tap drill for the fluteless/form taps, unless the wall is really thin you don't get a lot of deformation. I have a friend who does 2-56 holes all the time and he only uses the form taps anymore. He also has a slick tapping arm:
http://flexarminc.com/flex1.htm
Too expensive for me though...I do use a tapping head an awful lot anymore, and I have just strated playing with threadmilling on the CNC...
I use my Taig tailstock for holding taps - it has a lever arm instead of a screw so it's really easy, but I know what you mean about feel with the tailstock, if you can get into that 1/4 turn at a time groove...
On the body jewelry thing I had a nice gig for a while making tiny nose studs(turning 14ga. down to 18ga and making a ball) for a local shop, and once had to modify a 2ga.(!) hoop that was causing some prince-albert-related discomfort - I made sure that thing was autoclaved 1000 times before consenting to work on it!
And yes, you can never have too many tools...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:32768
