Macro Photography Light Source Using Cold Cathode Lights
When shooting using a light tent a low intensity light source is quite useful. The CCFL (cold cathode fluorescent light) found in LCD screens is perfect for this purpose. CCFL and the associated light scattering panels can be found in broken laptop and lcd screens for virtually nothing.
This Instructable shows how to use the a salvaged panel, a DC power source and inverter to create a large, low intensity light.
Some Words Of Warning
This project involves electricity, high voltage and soldering. If you do not feel confident about working with any of these things, do not attempt this project.
Step 1Materials
You will need the following materials:
  • Broken LCD panel with a functioning Cold Cathode Fluorescent Light tube
  • DC-AC inverter for your LCD panel and hookup harness
  • DC power source capable of producing at least 12V
  • Soldering Iron
  • Selection of resistors (for a 12V power supply a 70K Ohm and 50K Ohm)
  • Single Pull, Single Throw switch (SPST)
  • Proto/Breadboard
  • Hookup Wire
  • Screwdrivers and other implements of destruction
  • COMMON SENSE FOR WORKING WITH HIGH VOLTAGE
31 comments
Mar 2, 2009. 8:02 PMReCreate says:
Its ok,the "High voltage" is only 50 volts Really,I got shocked by this once and i am not dead.
Mar 3, 2009. 9:13 AMReCreate says:
Umm...no to prove my theory,i connected a inverter from a 5 inch screen to a 13 inch,and it lights up perfectly fine Also,somewhere i saw that the voltage for backlights are about 48-49 Volts AC TRUE,It does use a massive amount of electricity to start the bulb,but thats for a very short amount of time,like a few Miliseconds
Mar 3, 2009. 5:44 PMReCreate says:
sigh... no i connected my 14 inch CCFL to an inverter for a 6 inch and guess what,it lit up perfectly fine BUT whatever you win
Mar 11, 2010. 8:03 AMSgtSlaughter says:
You are totally missing what he is saying.
Mar 11, 2010. 11:26 AMReCreate says:
Congratulations my friend. Any other ancient comments you'd like to dig up?
Mar 11, 2010. 12:09 PMSgtSlaughter says:
Don't be dense. The concept of a "dead comment" at instructables is foolish at best
Jun 3, 2010. 2:37 AMcritterfluffy says:
Especially if the thread is talking about a situation that might lead to death.
Mar 22, 2010. 8:25 PMReCreate says:
I don't mean to be rude, But in other words what i meant was: I don't care.
Jan 28, 2008. 3:18 PMincorrigible packrat says:
If the inverter and or ccfl from the laptop is euchred, you could use the inverter and or ccfl assembly from an old flatbed scanner. You could eschew the laptop panel entirely, and use the scanner's platen glass with a piece of paper or something, as a diffuser, although I'm not sure how well that would work.
Feb 21, 2008. 6:11 AMincorrigible packrat says:
I agree that the lcd panel diffuser works dandily, I was just thinking that if one didn't have ready access to an old laptop, the paper and glass would be a cheaper substitute.
Feb 26, 2008. 6:22 AMincorrigible packrat says:
Probably would work better. Now, how do we remove the stockings from those two white ladies?
Mar 11, 2010. 10:44 AMSgtSlaughter says:
Take them to dinner and a movie first. Don't rush the endgame. Unless your in college. Then just grab what you want.
Mar 3, 2009. 6:22 PM-henry- says:
Here's a simpler idea: Instead of removing the backlight, just turn the screen on high brightness and open some blank white file. just a suggestion
Mar 4, 2009. 1:09 PM-henry- says:
True, just a suggestion.
Sep 13, 2008. 7:36 AMteddlesruss says:
Scanner lights are definitely the go - the inverters are generally separate from the driver boards to save having to isolate circuits, they generally expect 12V as the power supply, and they run for ages. Get a piece of lucite or other clear plastic tube, slide in the CCFL and inverter circuit, seal with silicon, and you have a good 12V trouble light. I used one of these as a reading light for months, it still works but I've since bought a real reading lamp... %)
Jan 5, 2008. 8:23 AMMyself says:
When I initially saw the title of this instructable, I thought it was just another desk lamp made with a CCFL, and I was going to say "you know you can buy those premade now", but now that I see you used the diffuser panel too, I'm impressed!
I'm laughing because I've used my laptop's LCD as a diffuse light source before, just by displaying an all-white screen. Just shove the keyboard part under your light tent's base so you can get the light right up close to the subject. Hint: Use a paint program to flood-fill the screen with different colors, and it's like a lamp with adjustable filters! If you're feeling creative, display different patterns of color on the screen and watch the way the casts and shadows play on the subject. That could be its own instructable, actually.
Feb 20, 2008. 2:43 AMELF says:
Why not extract the one in the panel you extracted from the laptop?
Feb 20, 2008. 5:19 AMELF says:
Oh, but I meant disassembling the actual panel, to extract the 2 sheets of polarizing film inside them. If you're careful, and wera gloves so you don't get any of the crystals on your hands, there shouldn't be a problem. And most often you'd have to seriously damage the two thin pieces of glass between which the crystals are. Only problem I know of with this is that sometimes the manufacturer just glues the film onto the glass. Sometimes it's not the same piece of glass that's holding the crystals, but sometimes it is (usually small screens, like PDA's and other compact units have it all glued together) I bought 3x A4-sized sheets for about $40 including shipping (to Denmark). Should I dig up the web-site for you? Took them 4 days to deliver, and that was in the christmas holiday...
Feb 19, 2008. 8:04 PMGunk on Floor says:
Great instructable and simply beautiful photos.
Jan 1, 2008. 5:14 PMSurferGeek says:
I like the idea of reusing a LCD you might have lying around but in the long run it would be cheaper buying a couple of CFL. One LCD "light panel" only gives you light from one side.
Dec 31, 2007. 4:17 PMGorillazMiko says:
Awesome!!!! Seriously, this is super cool, I might show this too my friend because she is really good at photography, and photoshop and stuff, she might like this, thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:txoof
