Step 14Jaw Mechanism Wiring Harness
For quick disconnects I used motorcycle style bullet nose connectors, but 3/16 spade quick-disconnects are more readily available at most hardware stores.
Polarity of jaw motor connections should be such that with the coil of the DPDT relay not energized the motor turns in the direction that moves the turnbuckle moves away for the chuck. An easy way to determine correct connection is by using jumper wires to test the connection between the motor and drill battery.
Jaw Mechanism Wiring.pdf402 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
