Step 2Assemble the "Business End"
iImage Information
Here's where ya'll get creative. You don't have to use the parts I used, but that's what I built it out of; therefore, that's what I'm going to talk about. Part One: You absolutely HAVE to build this part first. DO NOT try to build your Ray directly on the lamp. Failure is inevitable due to the unstable nature of the lamp. Take your Vaccuum Cleaner Motor or whatever you chose and attatch the "Concentrator"(that dish shaped piece on ray guns towards the end)to it. The Concentrator should be the transition between the motor and the "barrel" of the Ray assembly. I used hot glue being as that's what I had. If your looking at Instructables you probably own a hot glue gun and it shouldn't be a problem. Part Two: Now assemble the barrel. I used a clear plasic rod I found in a fax machine and the tip of a laser pointer. You can use a metal rod or pipe and a pen tip if you want. Feel free to experiment, since it's hot glue you can always tear it apart and try again(usually). Then, attatch the barrel to the concentrator.
