Unfortunately, you lack the blueprints for such a device. Lucky for you, I'm going to tell you how to build your own worm-hole generator!
OK, my computer is stupid and it won't let me put notes on the picture right now, so I'll pu them here.
This is the Generator...behind it is a microscope and a typewriter...and yes, that is a Sesame Street placemat.
Remove these ads by
Signing UpStep 1Get The Materials
You need something to house your generator. I used some sort of strainer, but ultimately, it's up to you.
Then you need some parts, use whatever you want, just make sure you can explain how it works. If you can't then you probably won't be able to teleport anywhere. Look at the picture to see what I used.
Same story as the Intro, here's the notes...Starting fom TOP LEFT and continuing as if you were reading.
Strainer, Large Spring, Two Cylindrical Electronic Components (I don't know what they're called), Cone Shaped Speaker, Button From Jacket, Top Of Marker, Lightbulb, LED Display, Radiator From VCR, Plastic Sample Jar. next row
Two Pieces Of Metal, Washer, Switch From Lamp Used For Shrink Ray, Push Button, Battery, Spring, Three Black Metal Rings, Speaker, And Two Speaker Magnet Things (the circular part on the back).
Let me know please my moble number is 07760299362 my name is Tony.
oh and the "electrical cylinders" are called capacitors
:D
1) using NUCLEAR FISSION, dissassemble yourself into HEAT ENERGY, have a sensor pick up this energy and turn it into electrical energy.
2) Using NUCLEAR FUSION, reassemble youself into matter
IN OTHER WORDS ITS MAGIC.
PS: no antimatter is required.
Did i mention that THIS IS EUREKA!!!!
