Madamp G3 Blues Kit
2,618
17
4
Posted
Introduction: Madamp G3 Blues Kit
Yeah so I like building stuff, and my Blackstar HT-1R does not have a lot of headroom on the clean side and I found the Madamp G3 Blues kit that was not too expensive. It's a 3W tube amp and it seemed like a fun project.
Step 1: Soldering
The kit took a while to ship but once it came it had everything included.
The components are soldered to a board with preinstalled lugs, you need to bend the lugs a bit.
Step 2: Pots
Then the pots, you mount them on the outside as you solder them to make it easier to reach. Then they are moved to the inside.
Step 3: More Soldering
Then the transformer and the tube sockets are mounted on the underside of the chassis and the wires come through and connected to the board.
The kit comes with very clear instructions.
Step 4: Testing
Then it was time to test it. Although I am an electrician, connecting this to the wall outlet was a bit scary.
I took my time and went through the check list and got all the correct measurements before I plugged my guitar into the amp. It works and sound good, perfect volume for at home practice. It can be played at low volume but can be cranked a little bit over the neighbor friendly level if you want, but not by much. But that is as loud as it gets, you wont be able to use it at any gigs.
Step 5: Enclosure
Keeping the amp on a plastic box was not a lasting solution so I used SketchUp to make an enclosure drawing. I had some MDF left from my guitar case project and built it. I made a panel for the front and back but I was not happy with it. But it had to do for the moment.
Step 6: With Some Paint
Step 7: New Front Panel
I used a paper to make a template for a new panel and used a jigsaw and a router to shape it.
Step 8: Tolex
I ordered some red Tolex, a handle, rubber feet and corners. Sadly the corners did not have the correct radius, or the other way around ;), so I could not use them.
Step 9: Draping
I watched a good video on how to apply the tolex and did my best to adapt it to my design.
Sadly I did not think my design through in ways of draping it, so there where some parts on the front that where to difficult for me to do well. I had to add som small stripes of tolex to cover the holes. At first I was very disappointed but in the end I think it's alright. And the the red and black looks really good in my opinion.
I rerouted the edges to 1/2 radius and switched my Ebay corners with the ones on my Harley Benton 1x12s.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    4 Comments
    what is that liquid stuff in the amp and what does it do.
    Hi.
    There is no liquid in the amp but now that you mention it I have to admit that the upside down tubes do look they have quicksilver in them or something when they are upside down :)
    Those are the heart of a tube amp. The vacuum tubes (or vacuum valves of you will) are used to amplify the signal from your guitar.
    You can read more on Wikipedia for instance, or maybe this article.
    Congratulations, you now have the ability to produce one of my favorite professional recording studio effects, guitar amp overdrive! You can overdrive the input of that little guy you built with just about any preamp available. It's not about super loud levels, the amount of electrons that can be moved across the tube grid is limited so any level that exceeds the tubes electron moving capability will be clipped and you end up with a nice mellow "rounding off" distortion as opposed to a transistor "bite off" You can now adjust the output level to match the situation. As-is, for in home practice or through another amplifier or the PA system to blast through any size venue. No matter what, you got the sound !
    The amp itself has a bit of nice distortion but it get's kind of loud for at home playing even though it's only a 3W amp. I also have a TS808 clone (-ish) as overdrive, it has it's own Instructable project.
