Macgyver-Cardboard & Duct Tape Solar Charger
1,417
10
8
Posted in TechnologyGadgets
Introduction: Macgyver-Cardboard & Duct Tape Solar Charger
About: I'm a lover, I'm a fighter, I'm survivor, interested in music, electronic, robotics, automation, programming, alternative energy, survival, fishing, archery, cooking, skilled at welding and metalworking, wo...
Sometimes you need electricity to charge your batteries, but if you're limited to cardboard, duct tape and a bit of electrical components, don't wory this simple solar charger wil help you.
You will need:
-Cardboard
-Duct tape
-Solar cell (3v)
-Diod's
Tool's:
-scissors
-scalpel
Step 1: Making a Box
Cut out a cardboard box so It can fit solar panel (6x6 and 3 centimeters deep)
You will get a box with displacement of about 108 cubic centimeters.
Step 2: Making a Circuit
Make a simple Graco's compound whit 4 diod's  http://img859.imageshack.us/img859/9834/napajanjesamo1.gif
Step 3: Final
This is It now you can charge your batterys ( 1,5 volts)
Stay safe and think smart.
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    8 Comments
    why on earth are you running a bridge rectifire on dc voltage you only need one when changing ac to dc voltage
    here you only need one diode on the + side of the solar panel so the power goes from the panel to the battery in daylight so when the panel is in dark the battery can not dump power into the panel and discharge
    with a bridge rectifire your wasting over 1.4 volts
    ethern if the panel is 3 volt you can still safly charge a 1.2 volt battery it will just start charging in lower light conditions
    How would an LED do?
    For ah blocking diode on such ah small charging system...
    no because the forwed voltage drop is higher on the led ideal you wont a Schottky diode the forwed voltage drop is a lot lower then a normal diode
    Ok, I know I accidentally put that their :D I m Noob
