Magic Choco-Flan / Chocolate Cake and Flan
1,099
44
Published
Introduction: Magic Choco-Flan / Chocolate Cake and Flan
About: Construction grade lumber is cheap and readily available, with a little thought and effort it can be transformed into a piece of art. - Ryan and Viviana.
Easy two layer cake, one part cake other part flan. Both pieces are baked together, they magically separate creating two delicious layers. Great way to super charge a chocolate cake out of a box.
Step 1: Cooking Utensils / Ingridents
Utensils
Glass baking pan
Bundt pan
Mixer - you could hand mix
Measuring cup
Aluminum foil
Blender
Ingridents
Favorite chocolate cake box mix
Eggs
Whole milk
Condensed milk
Caramel
Vegetable oil
None stick spray
Step 2: Mixing Ingridents
Cake
Forget the instructions on the cake box. All you will need is the cake mix, 1/2 cup vegetable oil, 3 eggs and one cup water. Place all in a mixing bowl and blend with the mixer until you achieve a smooth batter.
Flan
Time to get out the blender. I like to use a blender because it produces a smoother texture with half the effort of a hand mixer. Place 14 oz condensed milk, 4 eggs and 1 cup on milk in the blender. Blend for about a minute, the batter should be runny, slightly thicker than milk.
Step 3: Layering
Caramel layer
Spray your bundt pan with a none stick cooking spray. Cover the bottom of the bundt pan with the caramel, I use about a quarter of the little jar of caramel in the picture. If you are a caramel lover go nuts!
Cake
Pour the cake batter in next, nothing special right on top of the caramel.
Flan
Pour the flan mixture on to the cake batter, it will blend into the batter, don't worry. Try to pour it evenly around the bundt pan.
Step 4: Baking
Cover the top of the bundt pan with aluminum foil. Place the bundt pan in the glass baking tray. Fill the baking tray with an inch of hot water. Have the oven preheated to 350 degrees. Bake the cake for an 1hr 5min on the middle rack, or until a tooth pick comes out without goop.
Remove aluminum foil and allow to cool for at least an hour.
Step 5: Serving
After cooling, place a large plate over the top of the bundt pan. Cross you fingers, place pressure on the plate and the bottom of the bunt pan and give it the old flipper'ru! You will end up with results like the picture. Place the cake in the fridge and serve cold.
Step 6: Conclusion
This is an awesome desert, very rich and creamy, way better than a plane old box mix. Let everyone think you slaved in the kitchen creating this beast of a cake. By the way, it keeps great in the fridge. Thanks for showing interest!
Viviana
If you give this a try, which I hope you do, please let me know what you think/taste!
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
