So after some brain storming I decided to make them myself with the help of two friends. We had a lot of fun and were surprised, how good they turned out.
Step 1: Stuff you need
- 500g sugar
- a tablespoon of corn syrup
- white and black chocolate depending on the type, that you would like to make
- Aluminium foil
- wood pole or a long wooden spoon with a diameter of one cm
- fondant (if you need a recipe, check out this site)
- icing colours
- wire
method one: (Indicator reaction)
- red cabbage sauce (as a pH-indicator)
- L-Arginin (you can get it in the apothecary)
- Citric acid (you can get it in the apothecary)
- powdered food colouring
- Vitamin B2
Step 2: Making the mould
| Albus Dumbledore | 16 inch |
| Draco Malfoy | 10 inch |
| Hermione Granger | 10.75 inch |
| Harry Potter | 11 inch |
| Ron Weasley | 14 inch (his second one) |
| Rubeus Hagrid | 16 inch |
| Lord Voldemort | 13.5 inch |
To prevent the hot liquid sugar burning your hand, we are going to build a small handle out of wire, as shown in the fourth picture.
Step 3: Cooking the sugar
Add about 250 ml of water to 500 g of sugar and slowly heat the mixture. Stir until it starts boiling and add a tablespoon of corn syrup. Let it cook until it has about 300°F, if you want you can add food colouring. Set the pot for about 10 second on a table cloth and after that time CAREFULLY pour it into the aluminium forms.
If you don't have a candy thermometer don't worry, you can find out whether you mixture is ready, by taking a spoon and letting a huge drop of it fall into cold water, if it immediately hardens and you can break it like glass, it's ready.
Hints on cooking sugar:
If you are having problems with your sugar crystallizing, instead of having a nice clear result, try using a brush with a little bit of water and wipe the inside of your cooking pot with it until there is no more sugar that has crystallized.
Another thing you can try is to dip the pot into room temperature water, to immediately stop the cooking process, after the sugar has reached 300°F.
Step 4: Decoration
We covered the rest of the wands with chocolate, as shown in the pictures. If you want them to colour your tongue add powdered food colouring to it. It will only stain your tongue and not the chocolate.
After you are done place your wands in the fridge.
Step 5: The fun part
Type one:
As shown in the video, in the intro step, you can produce a nice indicator reaction with your wands and red cabbage juice. All you need is a base (in our case L-Arginin) and an acid (in our case citric acid). Dip your wand into water and afterwards into one of the powders. If you now stir with it in the red cabbage juice (dilute it with a bit of water) it will change its colour.
Type two:
As you can see in the second and third picture, if you add powdered food colouring to your chocolate the wand will colour your tongue, while you are eating it.
Type three:
If you dip your wand into vitamin B2 and then into water, it will start to glow under UV light.
Visit Our Store »
Go Pro Today »
what did i do wrong?
