3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magic POV Wand (yet another POV toy)
NEW!  (7/12/2009) This kit has been upgraded to a professionally manufactured circuit board and the price has been reduced to only $8 per kit. (For educators, a classroom set of 32 kits is being offered for only $5.50 per kit.)
This Persistence of Vision (POV) toy is simple to assemble and fascinating to play with.  It is a good introduction to digital electronics and soldering.  It works by flashing each column of “pixels” in rapid succession producing the illusion of text in mid-air.  You can program in your own messages using two push-buttons.  The message is saved in “Flash” memory and will remain in the MCU’s (PIC16F628a) memory even when powered off.  The message can be changed as often as you like.
This POV toy is similar to the MiniPOV3 with a few important exceptions:
*  Button cell battery - more portable.  Easier to mount onto a bicycle or other spinning object.
*  Change the message without using a computer.
*  Less components to solder in.
*  Less expensive ( Now only $8!
Buy kits at www.chinchillasoft.com/projects.aspx
Watch Video: http://www.youtube.com/watch?v=SAk2QtPzHrU
Step 1What you need
What you need
Tools:
Soldering iron
Solder
Everything pictured here is included in the kit.  If you already have most of these components, you can order the circuit board and/or the programmed chip individually.
ID Qty Part
A 2 Momentary Push-buttons
B 7  Diffuse Red LEDs
C 7 200 ohm resistors
D 1 Mini Slide Switch
E 1 18-pin IC Socket
F 1 Programmed Integrated Circuit
G 1 CR2032 Button Cell Battery
H 1 Button Cell Battery Clip
I 1 Engraved Circuit Board
60 comments
1-40 of 60next »
May 24, 2012. 11:39 AMnodoubtman says:
With wish compiler do you compile your c source code?
thank you!
marC:)
Mar 12, 2010. 12:34 PMdumes79 says:
 Just bought the kit from your website.  Do I need software?
Jul 1, 2011. 4:48 AMsmnoor88 says:
hello sir plz give me hex file of Magic POV Wand when i click on Magic POV Wand.hex12 KB ANOTHER FORMATE FILE IS OPEN (FR6I64EGC4G0NZB.tmp)
PLZZZ SEND ME REAL HEX FILE ON NOOR.RAHMAN88@GMAIL.COM
I AM VERY THANK FULL TO U
May 24, 2012. 8:31 AMnodoubtman says:
rename it : magic Pov wand.hex
thank you!
marC:)
May 1, 2011. 8:57 AMJolenelim says:
hi releddington,
if i buy the programming chip itself.how long can u deliver to spore.
Mar 31, 2010. 12:35 PMdumes79 says:
 The kit just came in.  It works perfect.
Apr 19, 2011. 4:50 PMfranmazz says:
can you add the printed circuit? please
Jan 7, 2012. 5:07 AMpalurdo says:
Thankyou for sharing the code and schematic. I uploaded my PCB design for everybody who want to use it without having to design it from scratch I had to do because mi case it was a matter of "emergency gift" (when you remember that today is an important day for somebody, you know...)
http://www.mediafire.com/?pw73i7eefx00zyh
I forgot to include a power switch so you have to remove de battery if you want to turn off the device. Once built the PCB and soldered the parts, the circuit worked as you described, rleddington.
Again, Thankyou very much.
Mar 31, 2012. 12:19 PMdespoto says:
Thank you for link with deleted file ...
Apr 18, 2012. 4:41 AMpalurdo says:
Ok, try this link:
http://mural.uv.es/mabuva/Ledwand.rar
It's a permanent link
Apr 18, 2012. 4:23 AMpalurdo says:
Sorry, i didn't notice the file was deleted. This copyright conspirancy than came from the megaupload issue has led everybody crazy about storing files at the cloud. Please keep in touch so i will upload again the file quite soon in a different server.
Thankyou for your understanding.
Mar 31, 2012. 12:27 PMdespoto says:
Would you like to explain to me why downloaded code (.hex) in program mode works inverse (LEDs that should be on are off and vice verse) ? I suppose that message will be displayed inverse in further action . In "without mc-chip mode" testing was OK......any suggestions?
Jan 28, 2012. 5:00 PMnodoubtman says:
how can you send a message with 7 led?
thank you!
marC:)
Oct 26, 2011. 12:57 PM16zzundel5 says:
I just bought the kit. I am so excited to build this!
Jul 13, 2011. 6:42 AMrobot1398 says:
is there a messege already there or do i have to program the message using the 2 switches
Jul 13, 2011. 7:33 PMrobot1398 says:
ok
May 24, 2011. 2:31 AMsmnoor88 says:
Jun 30, 2011. 8:09 PMvignesh1990 says:
ya i to have the same problem the hex file is in different formate
Jun 6, 2011. 2:07 AMmedo50 says:
gooooooooooood
Apr 22, 2011. 8:06 AMrubenrs says:
Hi rleddington, how to reset the message? have to reset or letter by letter?
Thanks
Rubens
Apr 22, 2011. 12:12 PMrubenrs says:
Thanks for the reply
I think my problem is to push the button confirms, sometimes I think it confirms the two times.
But I think it got the knack.
Thanks
Apr 9, 2011. 6:13 AMyaly says:
i have PIC16f84a will it work?
how to i edit the files to accept it?
Feb 27, 2011. 8:10 PMrabbsword says:
already order but my package not arrived almost 2 month...:(
Aug 5, 2010. 3:12 PMmilian579 says:
where is the schematic diagram? can't understand the circuit at the PCB cause it's not very clear... please send me a schematic diagram.. thank you... adsman579@yahoo.com
Jul 28, 2010. 5:36 PMboozo says:
hey nice work i did it and i made all the test and evrthing workd as you said and made the hex file the probl is when i am finsh i put it in the pov but dont work just one light up so can you plz help me and send me your hex file my be it will work thank you for your time
Jul 22, 2010. 4:48 PMshaf789 says:
how to program the 16F628A.??? plz tell
Jul 27, 2010. 11:01 PMshaf789 says:
do u have Cheap PIC Programmer simple diagram ?
Jun 18, 2010. 2:29 AMlaciubul says:
Do you send a .hex file of Magic POV Wand to me?
1-40 of 60next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:rleddington(ChinchillaSoft)
