that would make a awesome work table, tank what im working on apart flip for tool and screw storage, when done repairing flip back and have all my stuff back on top.
um... use it to hide away your unfinished projects from people with distractable eyes. or better yet, when someone complains about your mess flip the table-top and voila! mess gone ;-)
you make the split long-ways instead of width-ways so that there is less to swing, and put it smack dab in the center. then you can attach the cloth to the complete outer edge of both sides. full coverage and easier to swing without watching out for the fan!
plus you could use the idea i mentioned below by attaching the cloth to the surface near the center of the leaf that will be in the back, so that it'll pull it up and hide it better. or use a spring to attach it right on the seam so it can be tight when there's nothing in it, and stretch when there is.
A picture's worth a thousand words, but some times you do need an explanation of your steps. This is really cool but it's really vague when you only have 3-4 words to go on.
Nifty but needs refining. Also could do with some better aesthetics. I wouldn't want this in my living room. Even if you used better, more attractive materials I think it would be hard to make this one look classy.
not really... that's what trim was invented for. keep all the mechanics enclosed under the trim and you'd never see anything but a normal table besides the gaps between the sides. besides, there's always a table cloth to cover the whole thing. as long as the legs look good, you can't fail!
Could have the cloth go all the way to the end that doesn't move, instead of just to the seam. It'll still work the same, and it'll look a bit more refined. Over all, this isn't a bad idea.
or attach the center point of the cloth to the hinges with springs so it can stretch however far it needs to accommodate the contents, and when nothing is in it, it'll be pulled all the way tight. depending on how good your springs are.
GREAT IDEA , keep it up, Though it will be hard to make without proper instructions which it is lacking. Check out my Design Cutting Table with revolving top in craft Section.
No offense but I have to use your comment as an example. When you say "it will be hard to make without proper instructions which it is lacking" Obviously it can't be too hard because this guy made it without having an instructable for him to use. I see similar comments a lot on here and while I agree that a step by step guide makes things much easier, thinking it through enables you to learn a lot more!
This is absolutely brilliant! Your instructables demonstrates that the human mind can and will come up with the most creative ideas. Perhaps there is hope for us all yet! :-)
But what if you added this idea as part of a larger project? Say, you built a side table to fit between two couches. This could be that feature you were looking for: even something as mundane as coasters could be magically revealed or hidden using this method.
