3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magic Tablet
Step 2Disassemble Magic Slate
Remove the backing from the Magic Slate by cutting or carefully tearing the glued-down bottom, left, and right edges. You should be able to remove the writing surface by pulling it vertically off the erasing cardboard tab.
Interesting note here: when I took mine apart I noticed that the erasing cardboard tab that helps separate the wax sheet and the plastic on top was cut out from a different children's toy or cartoon page. It's not visible unless you take it apart so it didn't matter if it matched the outside design. I thought this was a very cool use of recycling, wherever these are assembled.
As an aside, I'd always wondered how those magic slates work. Basically the bottom layer is coated in dark wax. When you press down on the top plastic layer it sticks to the wax, making it show through in that spot. When you separate the layers the image clears.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Natalie Freed
