Magic Trick: Coin-Thru-Can
 by GreenPhantom
Step 4: Tricky, tricky, tricky...
As the title suggests, this part can be...well, tricky, at first. Once your hand/coin hits the rim of the can, turn your hand so the audience cannot see the top of the can or your palm. Move your palm/coin on top on the can and position the coin in front of the tab (over the hole). Pop the tab with your fingers while keeping your thumb over the coin (you can also keep your whole palm over it if you can, this makes it harder for the audience to see the coin) and let the coin fall it. Sometimes you need to push it in but dont be so forceful that it makes an audible *SPLINK*.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
