Magic Tube
827
Posted
Introduction: Magic Tube
• In this tutorial i will explain how to create a fake tube and hide valuables like money,jewels....etc.
• It is very simple design and can be done by anyone.
• It is also simple life hack
things needed for this project
• old metallic tube
• cotton
• razor
• screw
• paperclip
• polythene cover
• pliers
Step 1: Let's Get Started
• unfolding the crimped end using hand.
• using razor make a small opening laterally.
make sure the opening doesn't reaches the ends. because it will blow up the whole plan.
• remove 3/4 of the contents using paper clip or any substitute materials.
Step 2: Make the Hole Bigger
make the hole bigger as per the required item which we are going to insert.
• and make the hole bigger
Step 3: Cleaning the Tube
clean away the medication using a cotton ball
Step 4: Making the Wrapper
use a polythene bag to wrap up the required items, so as there is a great chance of mixing up with medication.
cut out the required piece of polythene
make sure the cover is dry
Step 5: Time to Hide
• wrap the valuables (say paper) using a polythene piece as said above.
• carefully insert the material into the tube. Make sure the edges of tube doesn't get spoiled
• fold the remaining end of the tube and crimp it with pliers.
this should be in such a way that no one should tell the tube is once opened.
Step 6: See the Magic
so by hiding this way, even if some one take this tube and force its medications out your materials are still safe.
Step 7: Taking Out
The hidden item can be recovered by opening the crimped end.
Then using a paper clip we can pull it out.
Step 8:
I hope everyone enjoyed it.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
2 Comments
Good idea. No one will think to look in a tube of medicated cream.
