Step 2Modify the cap
Use a screwdriver to adjust the size of the hole if its just alittle too small... If its too loose, you may want to start over.
Use the file to smooth the top of the cap.
Run a nut down the bolt and slide through the cap.
Now install the other bolt Leaving a little gap at the end of the bolt about 1/3 of an inch so it will fit snug on in the camera.
Using two wrenches tighten the two bolts as tight as possible.
Add Comment
