Magnetic Burr Holder
437
9
6
Posted in WorkshopTools
Introduction: Magnetic Burr Holder
About: Retired and I make stuff
I use a Dremel type tool a lot and always sit in a comfortable chair with my workmate set up and I have made up a magnetic holder for the burrs I use most, a simple and easy idea that helps stop dropping burrs onto the floor
Step 1: Tools and Materials
Magnetron magnet from an old microwave,
An old piece of oak broom handle
Belt sander turned upside downand held in the workmate
Step 2: Build & Conclusion
Ok build is a little laughable. The magnet from the microwave is easy to get BUT I never touch the capacitor with my hands as it can hold a charge, do not do this if you aren't totally capable.
The broom handle I rounded both ends down, this took seconds only, just enough to tap the magnet onto the peg so it held, same applied to the end going into the workmate, these are pretty strong magnets and are perfect I have them on the walls to hold Allen keys etc in place so they don't get lost.
I find this works perfectly it takes up no space and can hold lots of burrs'
Thank you for taking the time to look and I hope it can help someone.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    6 Comments
    I've made similar to this with a magnetic knife bar (Ikea purchase) for my drill bits. Only caveat I'd have - DO NOT put your drill bits, burrs etc on there that you use on metal. They end up magnetised and when drilling (or grinding) metal, the waste can end up sticking to the bit. Gets very, very bloody annoying! Again, great for wood bits, spade bits etc. Also, I like to use some hot glue and stick a piece of metal to the end of my pencils (or any non-magnetic tool) then these stick on too.
    Hello Russell A very good point on the metal work, I have done similar and it does do your head in. Thank you for your comments they will be useful for others too
    Yes it does. Very much so! All good. Vote +1 given.
    I have made nearly similar thingy too.
    https://www.instructables.com/id/3D-Printed-Rorary-Tool-Drill-Bit-Holder/
    So simple but so good! Wish I had seen this a few days ago while I had been using my dremel and burrs. I'm sure they come to life when your not looking like toy story. voted!
    Thank you very much Sir it's much appreciated
