If you've ever played the game Funglish, this should be a familiar style of game. As a matter of fact, it's almost exactly the same. Just bigger. And designed around teachers. And magnetic. And adaptable. It's a lot of things that the original version isn't. And until Hasbro fires up the presses and builds some content-specific versions of the game, DIY is the best way to put this in front of your entire class. (If you're running stations, a mini-version is also really easy to set up, too.)
Here's an example of a large version being played by Alyson Hannigan and Ellen DeGeneres.
Powerpoint revolutionized Jeopardy! for the classroom. It was fun, it was academic, and it was a good way to learn to recall facts in high-pressure situations. It can take awhile to set up questions, though, and anything that takes too much extra prep just doesn't make it to the kids as often as it should. This game is really quick to set up: a quick whiteboard set up, then pull out the magnets, get a list of vocabulary words, and you're off to the races studying vocab at two levels:
- unit vocabulary
- adjective vocabulary
Here is the learning objective for this game:
By playing this game, students will demonstrate their knowledge of plate tectonics, earthquakes, and volcanoes through the use of age-appropriate vocabulary.
Standards addressed:
a. Students know evidence of plate tectonics is derived from the fit of the continents;
the location of earthquakes, volcanoes, and midocean ridges; and the distribution
of fossils, rock types, and ancient climatic zones.
b. Students know Earth is composed of several layers: a cold, brittle lithosphere; a
hot, convecting mantle; and a dense, metallic core.
c. Students know lithospheric plates the size of continents and oceans move at rates
of centimeters per year in response to movements in the mantle.
d. Students know that earthquakes are sudden motions along breaks in the crust
called faults and that volcanoes and fissures are locations where magma reaches
the surface.
e. Students know major geologic events, such as earthquakes, volcanic eruptions,
and mountain building, result from plate motions.
f. Students know how to explain major features of California geology (including
mountains, faults, volcanoes) in terms of plate tectonics.
*We're doing that. You'll notice in the rockier sections of this 'ible that it's geared toward sixth graders learning about geology.
Remove these ads by
Signing UpStep 1: Parts and Supplies
A magnetic board
People to play with
Content area vocabulary
Magnetic strips from the dollar store (~ 4"x12")
Whiteboard marker/chalk
Tools
Laser cutter (or a permanent marker of some kind)
Alternate option: For those of you without a good dollar store nearby, or who might prefer to print out the magnets, try these printable magnetic sheets. Color printers are far more ubiquitous than laser cutters. Amazon is easier to access than the Daiso on Market St. in San Francisco. You can also just draw stuff on. There are easier options, but I wanted to tempt fate by cutting vinyl with the improper tool.
Visit Our Store »
Go Pro Today »
1 person kept score for their group
1 person choose the topic and made the first guess then we went down the line
For final jeopardy, one person was designated as the writer to write down the answer. Maybe something similar to this can be used for your game, however I am having a hard time picturing this in action ( I think my brain is shot for today)
I'm thinking 1 person clue giver, 1person note taker, 1 person point tracker (and if you are doing multiplying such as in lower grades you can make the points worth more then 1 each so they skip count), 1 person reporter who tells the groups answer. Each round they rotate jobs.
large, orange, mechanical, man-made
Kind of:
confusing, smooth
Not:
wet, blue, human
Do I win a 23" VIZIO Television???
