Just to be up-front, this instructable doesn't contain details on how to build induction coils or the lights themselves. I adapted commercially available magnetic induction lights to fit my bike perfectly, opening up the cases so that I could separate the lights from the coils.
A short video is below, showing the initial test of the separated coil, the finished setup, and how it looks at night:
Read on to see how it was done!
Remove these ads by
Signing UpStep 1"Reelight," its Shortcomings, and Other Options
The problem with Reelights, though, is that they are mounted directly on the wheel axles. This makes the actual product small and compact (the coil and light are in one integrated unit) but has a number of shortcomings:
- The lights are very low to the ground, making them less apparent to drivers
- The arms can flex a bit as the magnets pass by them, so they have to be adjusted every so often
- The arms are kind of ugly
One last, big drawback of Reelights is their cost. They cost anywhere from $25 for a low-end one to $85 for a fully-featured pair, plus shipping. So I'm also including some links to help people get started with making their own induction coils, circuits, and lights.
- Here's a kit, called Freelights
- Here's a paper (PDF) that has basic DIY instructions. The real gold, here, is in the detailed calculations that will help you figure out how many turns you will need in your homemade induction coil.
- vbnicolau posted this awesome instructable on how to make your own circuit and lit using LEDs and a relay coil.
http://www.instructables.com/id/Contactless-dynamo-powering-bike-safety-lights/
I'd love to see photos of whatever you make, when you're done!
If this is not a problem in your area, these are well worth the money.
