3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magnetic Induction Bike Lights (Mod)
Step 2Break Open the Reelight
  • last photo ←
Reelights are glued together with some pretty hard-core adhesive, since they were never meant to be opened. You should probably do a neater job than I did. A dremel with a fine cutting wheel would serve you well; I went at it with a saw and a screwdriver and pried the thing open, which sadly cracked the case in a few places.
This step has a number of close-ups of the internals of the Reelight, for others' reference. These pics are for the red rear light; the white front light was identical except for the color of the plastic cover.
6 comments
Dec 17, 2011. 2:23 AMUnkful says:
Hey Nagutron, thanks you for these photos and share it, I'm really glad to see your manual, but I have 2 questions. What is capacitor's value (in F)? and, if you only put one of these, may be posible that only one of the couple of led works right? I think that so the coil makes AC and I think the leds are reverse biased to fully profit the AC. I think may be better put 2 capacitors, one for each led, what do you think?
Sep 3, 2009. 5:48 PMcantsolder says:
Which solder joint on the circuit is positive and which is negative? I plan to directly wire mine rather than use a jack. Also if thicker wiring was to be used on the coil would there be more windings or fewer windings? Do windings have to follow a certain direction?
Jul 30, 2009. 8:24 AMcantsolder says:
One reason why I went to this instructable was that my front Reelight 120 failed (the rear is still working great). I heard a ticking noise inside the housing just before it failed. When I opened up the housing the two strands going to the LEDs had completely broken off their solder joints, leaving the two strands attached to the coil. I think the fragile connection between the LED and coil strands broke during use and the rest broke off when I dremeled the housing. Reelight should have put in beefier wires as there is a lot of vibration on a bike wheel as well as jolts from everyday riding. Maybe speaker wires will work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:nagutron
I'm the former Frontend Engineer for Instructables. Problems with the site? It may have been my fault... Like what you see? Sing my praises!
