Step 4Induction Coil Housing: Back Wheel
Now, to build the housings for the induction coils. For the rear housing, I wanted an aerodynamic housing that would nestle into the rear triangle of my bike frame, right next to the axle. I cut this from a satellite dish (same one that provided me with the audio cables and jacks. Everything was carefully measured out and sketched onto the satellite dish, and then I cut out the housing and shaped it using a dremel.
The induction coil was then sealed with large amounts of hot glue and mounted into the housing. Hot glue was also used to mount the housing to the frame. Afterwards, I did a quick test to make sure that the wheel was inducting a current in the circuit, and that it indeed lit up the LEDs.
comment
Add Comment
Add Comment
