Magnetic Knife Rack - 3D Printing Build
664
13
Published
Introduction: Magnetic Knife Rack - 3D Printing Build
About: My name is Duncan Smith and I am a designer and maker using 3D printing to create awesome products for the home and office. Check out my website for more 3D printing builds or downloadable STL files.
We were using a standard knife block on the counter but I have always liked the idea of a magnetic knife rack on the wall, so this month I went to work designing a 3D printed version and here it is. Its a combination of 3D printed components, magnets, a walnut veneer strip, and a food safe wood finish.
Step 1: What You Will Need
Any/all necessary protective equipment.
All other items for this project can be found here: https://kit.com/adylinn/magnetic-knife-rack-3d-printing-build
Step 2: 3D Printed Parts
(~20 hours @ 60 mm/s)
  • Filament choice not important
  • 0.2mm or greater layer height
  • 15-20% infill
  • Support may be required depending on orientation of the parts
Step 3: Finishing and Assembling 3D Printed Parts
  1. Remove any support material if it was used.
  2. Sand the outer body parts and the front facing (bottom) strip on the
    base plate parts using 150 - 400 grit sandpaper until smooth.
  3. Use adhesive to combine the 3 outer body parts together and then the 3 base plate parts together.
  4. Use bondo spot putty to fill in and hide the seams. Once dry, sand until smooth.
  5. Using a lightly damp cloth, wipe down sanded parts to remove any dust.
  6. Apply 1-2 coats of primer.
  7. Lightly sand down dry primed parts with 600+ grit sandpaper.
  8. Using a lightly damp cloth, wipe down sanded parts to remove any dust.
  9. Apply 2-3 coats of white paint to the planter.
  10. Apply 1-2 coats of clear coat.
Step 4: Final Assembly and Installation
  1. Cut the veneer down to a strip 15.5" x 3.5".
  2. Use food-safe wood finish and apply to veneer strip.
  3. Use adhesive to glue the veneer strip to the assembled baseplate. It should align with the bottom strip of the baseplate.
  4. Use a hot glue gun to glue the magnets in place. It might be worth
    marking the locations of the knives and gluing the magnets in those locations for even spacing if not using bar/strip magnets to span the entire width.
  5. Adhere the baseplate assemble to the wall using screws.
  6. Install outer body cover over the baseplate assembly.
  7. Add your knives and enjoy your new magnetic knife rack!
Step 5: Wrap Up
Thanks for taking the time to explore the project, I hope you try it and
if you do I’d love to hear your feedback and see pictures of your build!
If you enjoy content like this check out my profile for more of my
Instructables or visit my website for more content including free designs to download and 3D print.
Step 6:
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
