Magnetic Knife Rack | a DIY Tutorial
1,893
42
Published
Introduction: Magnetic Knife Rack | a DIY Tutorial
About: Husband, Father, Woodworker based in Wilmington, NC
A Magnetic Knife Rack that hangs on the wall is a fun DIY project that does not cost a lot of money, looks great in your home or kitchen, and is relatively easy to build. My version of the Magnetic Knife Rack has plenty of holding power for even the heaviest of cleavers and knives.
For full write-up and video of this process, please see my article HOW TO BUILD A MAGNETIC KNIFE RACK
Step 1: Mill Lumber
You can buy S4S (surfaced four sides) lumber from your big box or local hardwood supplier and be ahead of the game. Or you can use rough lumber if you have the tools (jointer and planer) to prepare this wood for use.
I use rough lumber and like to leave it at least 3/4″, but preferably 1″, thick to allow plenty of room to seat the 1/2″ thick magnets with space to spare.
Step 2: Mark and Drill or Route Magnet Holes
I used 1/2″ by 1/2″ cylinder magnets for my wall hanging magnetic knife racks, so I space my 1/2″ holes 1″ apart. For these racks, the customer chose the HD version which consists of three rows of magnets instead of the standard two rows of magnets on a typical magnetic knife rack.
I then use a router with a 1/2″ up-spiral bit to bore these holes. You could also use a hand drill or drill press for these holes, I just find the router to be best for straight holes that can repeatedly get within 1/16″ or less from the face of the magnetic knife racks.
This bit does leave a little nib at the bottom of the holes that I am able to break away with this small chisel.
Step 3: Insert and Glue Magnets
Some people use epoxy, I prefer craft glue for the wall hanging magnetic knife racks. It is easy to work with and dries over night. After dry I sand down the excess with my rotary sander.
Step 4: Sand and Prep for Finishing
The last step before finishing is routing the edges of the face of the magnetic knife racks using either a round over or chamfer bit and then finish sanding the entire rack using progressive grits up to 220 grit.
Step 5: Finishing the Knife Rack
There are infinite options for finishing these wall hanging magnetic knife racks. My favorite option is using mineral oil and a mineral oil and beeswax mix just like I do on my cutting boards. This does require some maintenance and is not the best option when staining the wood like I did on these Curly Maple racks. For these I used 3 coats of Minwax Wipe On Satin Poly. I lightly sanded using 600 grit sandpaper between each coat. This provided a smooth finish that wasn’t too glossy.
Finally, I hope this has helped you pick up some tips and tricks or given you the confidence to go ahead and take a shot at building one of these wall hanging magnetic knife racks of your own!
View additional projects
View more tools from my shop
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
