Similar whiteboard wipers are available for about $10. I thought I'd give a few easy steps on how to make your own for only $1-2 depending on what you have available at home.
For this instructable you will need:
Tools Required:
- Screwdriver (phillips or torx depending on your mouse)
- Glue gun
- Wire cutters (optional)
- Scissors
- Pencil
- Broken mouse
- Strong magnets
- Felt
- Double-sided tape
- Pencil lead
Remove these ads by
Signing UpStep 1Gut it
My dead mouse had a screw on its belly. Removing this one screw let me prize it apart to expose its innards. I recommend you do this project with a computer mouse, not Canida's Mouse Mouse, real mice don't agree with magnets and their fur would get awfully mucky with whiteboard pens rubbing on their tummy.
Unplug the USB lead. Different mice might not be made with the same easy connector as mine, so if necessary, clip it off with some wire snips. (It may look cool with the wire snipped an inch from the input with the wires frayed, a patch as a prize to anyone that sends me a photo of theirs!)
Lift out the PCB and return the mouse wheel to the cradle it was in. Again, different mice will have different construction so you may need to keep part of the PCB in place so that your wheel will stay in the right place once finished. Put the PCB aside, it has loads of useful switches and other components which would be good for an electronics project later.
yay.
Now question time: what do you do when the sponge cloth is soaked with ink and won't clean anymore? Have you thought of any way to clean it that won't affect the rest of the mouse? Or is it possible to glue several layers of cloth that later can be easily removed as you need it?
a) Have two. When one sponge is saturated use the other whiteboard cleaner, take the saturated one home, rip off the sponge and replace it then take it back ready for when the other's finished.
b) Cut multiple pads. Attach a pad with double sided tape but leave extra strips underneath the pad with their backing on. When it's saturated, rip off the used up pad, remove the backing from the tape and stick a spare pad on.
c) Attach pads with velco? Probably the worst option.
This help? If you make one please post photos of them in use, on your board and finished, I'd love to include them in my instructable.
would the gap where the cable was be wide enough for a slim marker to be housed?
that is such a cool idea
congrats on the feature!
http://www.stumbleupon.com/su/2UqD1s/www.instructables.com/id/Magnetic-Mouse-Whiteboard-Wiper/
Btw quite deserving of the feature Jayefuu!
