Magnetic Oil Drain Bolt. (Transaxle or crankcase)
We all love our cars. they say that the cost of maintaining a car is higher than the cost of living. With the current cost of oil, I can see why. Rubber hoses, plastics, lubricants all come from petroleum.
I'm going to to show you a simple way to help increase your engine and manual transmission life by magnetizing the drainbolt.
Step 1Gather your materials.
You will need.
Drain bolt from your oil pan
Super glue - Make sure you get a super glue rated for metal and magnets. Krazy glue does have a product that will bond metal extremely well.
small neodymium magnet (I used 8mm x 3mm magnets)
Sand paper or steel wool
Degreaser (You can use dish soap in a pinch)
16 comments
Sep 27, 2006. 3:38 PMSurferGeek says:
You might want to try something like JB Weld rather than superglue as it's likely to not stand up to hot oil.
Sep 22, 2010. 9:30 PM2 stroke says:
what about welding the magnet to it
Oct 28, 2010. 8:06 PMcybermantic says:
Heat damages neodymium magnets
Oct 28, 2010. 9:17 PM2 stroke says:
oh i never knew that
Oct 1, 2006. 3:44 AMSaga says:
Buy a bunch of neodymium magnets and tape them around the oil filter. This way you don't have to worry about the magnet rattling loose from the oil plug and ending up swimming around your crankcase(which could end disasterously.) It's also possible to perform this without draining the oil and it's possible to use many, many more magnets than could ever fit on the end of a drain plug.
Jan 28, 2010. 10:50 AMtheatre_tech_guru says:
but some cars do not have an external oil filter
May 25, 2008. 7:19 PMJerryMopar says:
I totally agree with this!! ALL of the engines oil goes through the filter at some point in time, with more frequency than the oil would pass the drain plug. Plus, when you change the filter out, all the metal flakes stay INSIDE the filter and get THROWN AWAY with the filter.
Apr 30, 2007. 7:08 PMcarpespasm says:
that's a very good idea, i'll probably do that next oil change. thanks a lot!
Sep 27, 2006. 4:23 PMmodio says:
Why and how does this work?
Feb 22, 2009. 6:04 PMGamer917 says:
I was going to ask the same thing
Jul 1, 2008. 12:45 AMjim4850 says:
Sorry but i don't think neodymium magnets are a good idea. They may be as strong as buggery and a wonder at normal temperatures but they hate heat in excess of 80°C, it will weaken them or worse. Better to use old fashioned ferrite jobs, they should be good for 300° or at least more than oil in an engine should even reach.
Sep 27, 2006. 7:45 PMTrans_Am says:
Even the most basic transmission will have magnet in the drain pan, so that makes this kind of redundant, doesn't it?
Oct 12, 2006. 10:42 PMStratMan says:
It's an extremely good idea, and I've actually tossed a magnet in the oil pan on some of my cars, and if you ever need to drop the oil pan, you'll see just how much debris it can hold. (Potential damaging debris "not" going back in your engine.)
Sep 28, 2006. 2:11 AMtrebuchet03 says:
My standard shift has magnets in them... hell, even my father's old '84ish Mercedes 240 diesel had a magnet in there... just not on the plug itself :P
Sep 27, 2006. 7:46 PMTrans_Am says:
Forgot to mention, the metal shavings will collect in the magnet, preventing them from causing further harm to your precious gears.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:germanpickle
No thanks.
