Introduction: Magnetic Quick Wire Helper
I notices at my work desk that I needed a better way to store but get easy access to my pin wires used with my Arduino and breadboard. I was storing them all in a drawer, which made for frustrating hunting and pecking for the right length and color. So, I decided I needed a quick reference wire helper.
Step 1: 3D Files
Not having the equipment to create a metal or wood holder properly, I went with a 3D printed model. I found this one on Thingiverse noting it is a cable management thingy.
Step 2: Magnetic Help
I originally thought that using some magnets at the end of the base or along the teeth would help keep the wires in place. So I spend some time gluing neodymium magnets to the back. In hindsight, it helps a little bit, but not much. The design of the cable management thingy is sufficient to hold the wires in place without the magnets. So, it's up to you if you want to use them. I think mine would have been fine without them.
Step 3: Color Coding
Once I printed the cable management thingy, I just organized my wires based on length and color. I screwed it to a wood base which is withing reaching distance on my work bench for easy access. For the most part it stays out of the way until I need it. Then I can easily access the proper wire. Sometimes it's the little things that make all the difference. This little thing certainly made my projects easier, at least it appeared to be that way in my own mind.
Tech Contest
Formlabs Contest
