3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magnetic Rubik's Dice Cube
Magnetic Rubik\
This project is a modified version of gfixler's Magnetic Acrylic Rubik's Cube, and uses red translucent dice instead of clear acrylic cubes. I give credit for the dice idea to ella and andyholloway, who were going to build a dice cube, however I do not know if they ever finished.
I will assume, if you are reading this, that you have already read gfixler's Instructable. The primary purpose of this instructable is to highlight some of my modifications on his idea. So if you are planning on building one of these, I recommend you go and read his now.
The non-symetrical nature of some of the die patterns gives the dice cube an extra element of strategy not present in regular Rubik's Cubes. This variable of rotation is an aspect of the "sudocube," but the dice cube is easier to solve, because each face contains identical figures, and every cubie is unique--two properties of the original Rubik's Cube that are not carried over to the "sudocube."
Equipment & Parts List
  • 96 D32 Neodymium magnets (100 pack recommended)
  • 12 D62 Neodymium magnets
  • 27 3/4" or 19mm dice (30 recommended)
  • High Strength & Quick Drying Glue or Epoxy (transparent or translucent)
  • 3/16" split point drill bit
  • 3/8" split point drill bit
  • Scrap Wood or Metal to make a Die Jig
  • Carpenter's Square
  • Drill Press with stop
  • At least 3 clamps - more is better
  • Shop Vac
  • Standard head screwdriver
Update (2007-07-20)
It's been a while since I've been around here; lately my internet has been sporadic at best, and nonexistent at worst. But I'm here now and I'll try to get caught up. I've noticed that the same questions tend to come up again and again in comments, so I've decided to answer some of those here.
All in all, the cube cost me about $60, although at least a third of that was for shipping and handling, as well as the drill bits that I bought specifically for it.
Many people assume that the cube spins just like a normal rubik's cube (I did too at first), but in reality, the faces move in more of a snapping motion, which is quite satisfying, though it doesn't lend itself readily to speedcubing.
If you take the time to analyze the magnet orientations and polarities, you will probably come to the conclusion that creating a 2x2x2 cube with dice and magnets is impossible. Indeed, any magnetic cube with an even number of sides presents some interesting problems, but they aren't insurmountable ones. You just have to think outside the box (or in this case, the cube). I am in fact, currently making at 2x2 cube. I started a few weeks after I finished the 3x3, but I haven't worked on it since then until today. That being said, I should probably have it finished this weekend. I believe that a 4x4 would also be possible, though more difficult and certainly quite heavy. Anything higher than that is probably a pipe dream. (probably)
Update (2007-07-21)
Well, I finished the 2x2 cube this morning. It's really not a lot of work once you have the jig finished. In fact, it was more fun to make the 2x2 than the 3x3. That said, the end result for the 2x2 is less cool than the 3x3, and in retrospect, making the 3x3 is much more satisfying in the end. Anyway, check out the 2x2 cube.
Step 1Get the magnets.
Get the magnets.
For my cube, I decided to use D62 magnets for the connections between the core and centers, so that the cube would stay together better while being turned. D63 magnets will also work, but since they are thicker, it will be harder to glue them in.
For the rest of the connections, I used the same D32 magnets that gfixler used.
A total of 108 magnets are needed: 12 D62's and 96 D32's. Buy a 100 pack of D32 magnets, in case you lose a few or glue one in backwards.
When you get your magnets, the first thing you should do is mark them. Connect them all in one long "chain" and use a sharpie or other marker to mark the same side on each magnet. Make sure that the marked sides of the small magnets have the same polarity as the marked sides of the large magnets.
As for polarities, I used this method:
  • Core: All faces "Red"
  • Centers: Face touching core "Silver," other faces "Red"
  • Edges: Faces touching centers "Silver," other faces "Red"
  • Corners: All faces "Silver"
I don't know which sides were north or south, but since I marked red for one of the polarities on every single magnet, it doesn't really matter.
Using this method, most of the cubes have both polarities facing inward at some point. This should reduce the stress placed on the glue and reduce the chance of a magnet coming out. Additionally, the corners are attracted to the centers and core, which should help keep the corners stable while turning a layer in the finished cube.
While gluing the magnets in with this method, clamps are only needed for the core and corners. I recommend waiting 24 hours in between gluing the core magnets, as they are strong and very close to each other.
332 comments
1-40 of 332next »
Feb 24, 2007. 1:01 PMMastaAzumarek says:
:D finally made one on my own... one tip for those without a drill press but have a hand drill... good luck... mine came out to be a mess... i just kept thinkin to myself, "Man i wish i had a drill press, would make life so much easier" I used blue dice with mine :D No idea how this picture thing here works but the first is the completed cube, second is the mistake hole made, and third is where the magnets were put in incorrectly and i had to take them out and glue back in :P
Jul 8, 2007. 12:14 AMConsuela686 says:
Hey how exactly did you drill the holes with a hand drill? Did you need clamps and any other tools? Thanks
Jul 8, 2007. 12:33 AMMastaAzumarek says:
yep they're the blue ones from uncle's... thought i would use one of their specialty ones, but i liked the transparency
Jul 8, 2007. 12:37 AMMastaAzumarek says:
well... first i marked off the depth with tape, had to constantly take off and put back on... then i had work gloves that added padding for my fingers, then i held the dice extremely tight with my hand like a fist, then started to drill slowly, after i get deep enough i had a rubber pad which added grip to the dice that I put on there while i drilled with more pressure
Jul 16, 2007. 12:07 PMKoontay says:
Wow, nice cube! I am thinking about making a 2x2 cube, but I need the magnets.
Jul 19, 2007. 6:49 PMdrs2991 says:
You can't make a 2x2 with dice it just won't work because of the polarities... Well, you couldn't turn it... it would explode
Aug 15, 2007. 12:00 AMGonazar says:
Hey nice cube, just it's kinda hard to tell from the photos, since it's transparent can you see the glue and other marks that are in the third photo from the outside? Is it easy to tell or do you have to look closely? I unfortunately lack a drill press and will have to resort to the hand drilling method , I just wanna know if it will look anywhere as clean as the others from the outside. Thanks
Dec 8, 2007. 3:15 PMArthur Fierro says:
Hello burzvingion, I made some changes that result in a great stability of all layers. The core magnetos get in the central dice of each face, avoiding the layer slip. Strong magnetos and lubricant avoid other dice to pop. Magnetos: 11X05mm (core and central), 06X05mm (central, edges and corners). I had to change the places of the central and edges pieces 06X05mm magnetos. The corners magnetos keep at the center of the dice. May this dice cube be sold or there is some patent law that do not allow? Thank you for this great project. Arthur Fierro
Dec 13, 2007. 7:19 PMcaspian7 says:
I personally like the design idea. I found when I made mine it slips often irregularly--some magnets are in too deep, others just right, and others flush with the dice. I never considered rising above the side. As far as selling it, someone actually did sell his on ebay for $295-- a bit much if you ask me, but then again if someone was willing to pay that much, who am I to judge? Apparently they cannot be patented. On gfilxer's instructable, it is discussed the reason(s) why.
Dec 15, 2007. 2:19 AMArthur Fierro says:
I made one following the original project and this one with the core magnetos into the central pieces and You were right about the mechanical connection. This one is far far better to solve. $295!? Wow!!! Of course this is not easy to build but I was thinking something like $150 - $180 and giving up thinking it was too expensive to someone pay.
Dec 27, 2007. 7:46 AMxarcanx says:
hi arthur, I'm brazilian as well. where did you bought your magnets? in a fast search in the net i could only find a 05x05 and a 10x05 and both with astronomical prices...by the way, this green one is really cool!
Dec 28, 2007. 2:35 AMArthur Fierro says:
Hello xarcanx, Thank you for your comment... Yes, I paid an astronomical price for either the magnetos and dice, that came from US, because importation taxes and freight are really expensive. I also made a fast search in the net, but it was enough to talk to a brazilian dice factory and discover that 19mm dice are not produced in Brazil, just 18mm or white 20mm. If you want, email me: arthurfierro09@hotmail.com
Jan 1, 2008. 2:03 PMJesus Wept says:
wow I really like what you did here. I just ordered my Equipment for this and can't wait to start. I am going to use your changes on the core.
Jan 3, 2008. 2:20 AMArthur Fierro says:
Hello Jesus Wept... Don't forget that if you change the core you must change the central and edges magnetos places. Thank you for the comment. arthur
Jan 6, 2008. 9:42 AMxarcanx says:
thanks, according to my calculations the magnetos from K&J Magnetics should be around R$46,00 taxes free. How much you paid with the taxes and all? Now, I really don't think the dices size matters anyway, the 19mm dice is just so the cube is the same size as a real Rubik's cube...
Jan 23, 2008. 6:05 AMArthur Fierro says:
I'm really sorry, I don't remember, but freight and importation taxes are very very expensive. I got many dice and magnetos to use the same freight as You can see. About the dice size, 01mm less in each face become a enormous difference at the final result. If you need, email me: arthurfierro09@hotmail.com
Jan 10, 2011. 12:55 AMdesmondtheredx says:
it wont fully work, when you rotate to some patterns it will fall apart
Dec 19, 2011. 5:58 PMFlying_MashedPotatoes says:
you obviously dont understand how it works.
Sep 20, 2011. 3:21 AMtpartic-gray says:
could you use earth magnets?
Sep 17, 2011. 4:02 AMtpartic-gray says:
what if u make them out of wooden cubes and stain the sides to different shades? it would be easier to drill and wont scratch as easy.
Sep 3, 2011. 1:18 PMMichaelhot1 says:
cool
May 12, 2011. 2:20 PMzipzapper859 says:
could you use hot glue or would it not hold up?
Apr 28, 2011. 8:38 AMfastback570 says:
You may not be down feeding fast enough if getting melting even before the drill bit is warm. increase feedrate.
Jan 21, 2011. 6:16 AMcalebman says:
WOWWWW!!!!!!!!!! EXCELNT!!!!! MY RESPECTS!!!!!
Mar 31, 2010. 1:42 PMninjutsu says:
I am about to start making mine this weekend, for anyone wondering about prices I am in Canada and in total my costs are around $50-60. I still need to go out and get glue, but I do not expect it to be very costly. I ordered my magnets from the one in the instructable, and I got my dice on eBay, which was allot cheaper.
Ill post my results when I am finished.
Apr 1, 2010. 6:10 AMninjutsu says:
ok so I went out and got the glue, and after standing there staring at all the glues I finely ended up going with a very similar epoxy that tries transparent, and in 5 min. it came to about $10 after tax. I got it at home hardware, but I would assume that you could get it at a Canadian tire, or hobby shop.
Apr 5, 2010. 9:27 AMninjutsu says:
ok so i have made it and it is finished ... finally : D. i will post pics of it soon. To be honest it took a lot longer than i thought, i used lapage epoxy, which dries very quickly. i could glue 4-8 magnets for each time i mixed the glue.  to apply the glue, i used q-tios that i pulled the cotton off of. and clamps, clamps are completly necessary.
the hardest part: doing the middle part, lineing up the drillpress
the easiest part .. . .... well it felt awesome to get it done XD
all that is left to do is clean up the extra glue that oosed out. lighter fluid or rubbing alchol should take it off. ill post pics in a day or two.
Dec 1, 2010. 6:23 PMninjutsu says:
sorry i never posted pics, i would now but someone got a hold of it and broke it. it was fun and really cool everyone i showed it to loved it. i see a lot of people talking about their fastest times and so i thought i would share. my fastest time is 32 seconds. an other thing i have done was solved two at once (one in each hand) in under 4 min.
where it sorry about the poor spelling. q-tips instead of q-tios. and the many other mistakes XD.
Oct 25, 2010. 7:01 AMSorunome says:
I made it, and it's great! I don't have any pics, but I wanted to ask if it is possible to make a 4 by 4 by 4 cube?
Oct 18, 2010. 7:39 PMHunter O. says:
Dang I really need to make one of these things! It would be really cool if you could make a 4x4 but for the core you would need a big marble-magnet thing
Sep 9, 2010. 11:19 AMfibersofgrace says:
Hey can you tell me if there is a way to do this so that a persosn could make jewelry... say make the cubes smaller and make a necklace?
You did a fantastic job... I have to admire it from afar... I do not have a drill press.
Boy if someone could invent something to center a hand drill we'd all be happy.
Congratulations on a gorgeous modernistic look, and play.
smiles
grace
Sep 5, 2010. 4:23 AMSorunome says:
Can you make a magnetical 4x4 rubiks cube??
Aug 23, 2010. 3:00 PMeurofyter966 says:
Wow, that is awesome.
May 23, 2008. 6:38 PMfastback570 says:
I am wondering if a 2 fluted end mill would work better esp. if the magnets are cylinder shaped. One thing I'd like to see is how do you figure out how to put the magnets so that pos+ lands to neg-. Do you start out with the positives all facing out from the center?
Jul 25, 2010. 3:56 PMrmelchiori says:
I would suggest a forstner bit. It drills perfectly round, straight sided holes with flat bottoms. There is a small center spur hole that would collect the excess glue. They are not that expensive. Cool instructable.
Jul 25, 2010. 2:51 PMkrickerd says:
How about using a spade bit such as: http://www.mytgtools.com/product.php?item=WSJ008002 ? This way the hole would have straight edges clear to the bottom instead of tapered - perfect for cylindrical magnets.
1-40 of 332next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:burzvingion
