Magnetic Vise Soft Jaws (w/ Silicone Adhesive)
3,088
56
Published
Introduction: Magnetic Vise Soft Jaws (w/ Silicone Adhesive)
About: -----------------------------------------------------------------15 year old, sick with a deadly disease called DIY-itis!-----------------------------------------------------------------Hi FTC! My I'bles con...
I was recently given a very old vise from my grandpa, I started using it, And for most projects, It's an amazing must have tool!
The problem with vises is that they have serrated jaws, Which are very aggressive and can leave marks on your work, Whether it's Wood, Metal, Or anything else.
After looking at some "Magnetic Soft Jaws for Your Vise", I came across Fikjast Scott's : Magnetic Rubber Jaws for a Vise. He used "Big Mistake" erasers as soft jaws. I was very fond of idea, But these erasers aren't very cheap, And I wanted to keep the project free.
After thinking and searching around in my room for something soft I could use, I came across the idea of using Silicone Adhesive. Silicone is a very soft and hard to rip (high tensile strength), Which is better than an eraser. I also had it laying around, Which was even better!
Here's what I came up with, And I made it in 10 minutes!
Step 1: What You'll Need:
Materials:
Silicone Adhesive
Two Identical Magnets
Tools:
Vise (Obviously, But it will also be used as a helping hand)
"Epoxy" Mixing Stick
Step 2: Choosing a Magnet
The magnets I chose were ones that were salvaged from old speakers. You can see how to salvage them on your own here
In the beginning, I wanted to use rectangular ceramic magnets, But I only had one, So I had to think of something else.
I started searching in my magnet collection, Until I found Two identical magnets that were around The same size of my bench vise's jaws. I also Didn't want them to be too thick, Because it wouldn't leave me any space to clamp materials down. Before starting, You might want to make sure that they're strong by squishing them (not too hard) in your vise, They shouldn't budge.
Step 3: Clamp, Add Silicone, & Flatten It Out
Clamp one magnet in your vise, And put some silicone on the top of it, As shown in picture #1.
Next, Use your mixing stick to spread the silicone until you have a flat layer. This is not very easy to do because the silicone is very sticky, It has to be fairly flat, Not perfectly flat.
Now let cure over-night to maximize the strength. Curing time depends on the kind of silicone adhesive that you're using, But overnight is always the answer (for silicone)
Now repeat the same process with the second magnet
That's basically it, This project took me about 10 minutes
Step 4: Storage / When I'm Not Using It
When I'm not using it, I put the magnets on the side of the vise, Near the anvil.
This storage method will slowly magnetize the vise, But I have no problem with that happening
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    2 Comments
    Clever idea. The magnets make them easy to attach and detach. Do you ever have problems with the magnets pushing each other away and messing up the allignment.
    Thanks, I've never had that problem, But I'll get back to you if it ever happens.
    I'm guessing that the force the keeps each magnet held to the jaw is a lot stronger than the force that makes them repel...
