loading
Step 5: Finished Spice Rack
For my spice rack I decided to stick all the tins to the front of my refrigerator.  There is room for 70 tins; 80 if I cram them a touch closer.  With the neodymium magnets they don't budge a bit when you open or close the door, no matter how hard you try.
Instead of your refrigerator door you could also stick them to a sheet of tin hung from the wall, strips of metal affixed to the inside of your cabinet doors or a magnetic whiteboard.
I built this and have been using these for about a year now. I love them, and have had a lot of compliments about them. I have a couple comments from what I learned, and a question about a problem I'm having.<br><br>I used super glue and decided to use two magnets. Sometimes I just have to learn the hard way. For the really heavy spices (think salt), two magnets was not enough. They would slide down the fridge. Also, after a few months, the superglue started to fail and the magnets started to come off the tins. I used JB Weld now and they are rock solid.<br><br>The really fine, ground spices (cinnamon for example) are giving me major problems. The fine dust gets between the lid and the rim of the tin and this makes it almost impossible to get the lid off. I definitely can't pull the lid off, and usually I can't twist it off either. I now have a pair of channel locks (pliers) in my kitchen that I use to get the lids off the ground spices. Anyone else having this problem? How do you keep the lids from binding?<br>
I had the same problem with cinnamon specifically. I never did find a good solution to that problem.<br><br>Anyone else have a tip?
<p>Well, it's been a while since your post, so I don't know if you still need an idea for a solution. The problem is that the times seal by side pressure. The tin sides are slightly narrower in diameter/circumference to allow lid to attach. It si that gap which accumulates powder.</p><p>I have two possible solutions (untried BTW) . If you can find a gasket that fits inside the lid, that will allow the wall of the tin to touch the lid preventing the powder getting into the gap. The lid just has to touch the lip of the tin wall.</p><p>The best would be a plastic ring of the type used for spice shakers - flexible. It should be a ring to preserve the clear view inside. Depending on availability and size of your lids, you could just modify a Ball jar gasket, or even cut a hole in the center of a Ball jar lid, if just the gasket is not available.</p><p>Another possibility is getting thin metal tape, about 1&quot; wide. Cut a strip equal to the inner circumference of the tin. Lengthwise, Fold over the tape to stick to itself, leaving another half inch exposed. Paste that on the inside of the tin so that it extends above the lip of the wall, sufficient to touch the lid when closed, and provide a slight pressure barrier, to prevent the powder from getting into the gap when closed. It should be completely invisible from the outside.</p>
<p>Try putting plastic wrap over the top of the jar first. Then screw on the lid. The plastic wrap forms a tighter seal, conforms to the threads, and forms an anti-friction barrier between any spilled powder and the lid. (I also do this to keep things from leaking, when transporting liquids or other leakables in a suitcase.)</p><p>Great post. I love magnets, but hadn't thought of this. (stupid) Question: could you not just put your magnets inside the jar at the bottom? They would stick to the jar, which would, in turn stick to the metal board.</p>
<p>If you have screw on lids, try some of that stretchy white plumbers tape around the threads on the container part.</p>
<p>Good idea with the plastic wrap. As for the magnets inside the jar - I read that the adhesive (JB Weld or whatever you use) might not be good to put with food. I have no idea if that's true, but it was enough for me to put the magnets on the outside.</p>
<p>I think agwh meant to skip the JB Weld altogether, and just have the magnets on the inside of the jars without any adhesives.</p>
<p>Yes, I meant put the magnets inside without the JB Weld. The magnets should stay put, due to, well, their magnetism. ;)</p>
<p>Here is a link to spice tins whose bottoms are already magnetized: </p><p>http://tinyurl.com/h7x69cw</p>
<p>I've had pretty good luck with rubbing the outside of the rim with a TINY bit of coconut oil so it will spin off next time it also cleans the powder off </p>
How about tapping off the lid except the contact point and spraying/painting that with a thin layer of plasi dip or rubber spray paint? I haven't done this so I don't know if it would work but I just thought if it works for Ball jars it might work for this.
Sorry, I don't follow you. So the plasti-dip on the outside of the lid so it is easier to grip? <br> <br>I'm still trying to find a solution to this problem, so I'd like to understand your idea better.
on the inside of the lid between the lid and the jar edge; however, more i think about it the more it seems that it won't work. the idea was to create a gasket-like effect so that the cinnamon will not slip between the lid and the edge of the jar, like on canning jars (http://www.canningbasics.com/images/canninglids2.jpg) but with out a two piece screw top it doesn't really work.
Oh, I see. That's a good idea, and one I haven't tried yet. I've got nothing to lose so I'll try it.
<p>Just be aware: In your best interest--careful how you use those magnets...things happen...for instance, if you had the magnets inside the tin and they ended up in your recipe somehow or the contents ate away at the magnet covering--not good. Yes, I know they are strong--but things happen:</p><p><a href="https://en.wikipedia.org/wiki/Neodymium_magnet" rel="nofollow">https://en.wikipedia.org/wiki/Neodymium_magnet</a></p><p>Swallowing a magnet for those who might have had surgery at one point and have staples or metal in their implants can cause serious harm or death--and you do not want them around children! </p>
<p>hi..i used it but a simple problem facing while opening the lid, the spices dropped out...so i decided to make a half lid open tin and the rounded sheet onwhich these tins are fixed, may be made moveable in circle to get the spices from the back of the fixed lid.....would it be suitable.....plz guide me</p>
<p>@ guaps </p><p>Maybe put the 3 magnets down the SIDE of the tin instead of on the bottom?</p><p>This will allow the tin to remain vertical and thus eliminate the problem.</p><p>Hope this helps :)</p>
<p>Love this idea as I have little space.</p><p>Thanks a lot for this :)</p>
<p>I have a cinnamon comment. Instead of storing the dry cinnamon, how 'bout buying cinnamon sticks and grinding it fresh? </p>
This works for some applications. However, it's very hard to grind cinnamon to the flour-like consistency of ground cinnamon at home. To do that you need a very high end grinder.
<p>made these about 8 months ago when we moved in to the new place for the spices i use most...works well for my purposes.</p><p>i bought my tins from uline.com and my magnets from ebay. </p><p>like some other people have mentioned, there is a bit of an issue with the really finely ground spices, but i have gotten into the habit of wiping the rim of the tin with a paper towel before i put the lid back on.</p><p>if i can figure out a way to keep the garlic powder from clumping, i will be in good shape.</p>
<p>This is about garlic salt, but might work for garlic powder, as well. I had so much trouble with clumping that finally I put the container in the freezer, and now it goes for a year or more and is always quite shakable. I realize that doing so would mean it couldn't be used in the fridge door &quot;rack,&quot; but might be worth it to save money on having to replace it frequently. </p>
<p>Adding some silicon dioxide (anti-caking agent) to your garlic powder might help prevent clumps (it's how the spice industry does it). Also, possibly adding something non-magnetic (such as a glass marble) might give you more 'clump-busting power' when shaking the grains loose.<br>https://www.americanspice.com/silicon-dioxide/<br><br>&quot;Simply Organic&quot; brand garlic powder is more coarsely ground than many &quot;garlic powders&quot; and is less prone to clumping. I buy it by brand specifically because of this fact (I don't care about 'organic' labels).</p>
<p>re lids getting stuck: I guess you could give the thread a quick wipe before closing tightly and maybe a rubber seal where lid meets jar. </p><p>I find the containers with the shaker perforations a bigger issue as there's always a bit of residue left that stops it sealing and the contents get damp - chicken salt, vegetable salt and any other salt-based premix of seasoning is the biggest problem but paprika, onion powder, garlic powder etc have the same. Your solution here would probably help solve it</p>
<p>Turning the fridge door into the spice rack - brilliant! Thank you</p>
<p>Ikea sells these containers &quot;already made&quot; (http://www.ikea.com/us/en/catalog/products/80102919/) - and I had several in which I put a spice blend containing garlic and/or salt - and there was a hygroscopic/galvanic reaction that ate right through the metal.</p><p>Caveat emptor.</p>
<p>A great idea that I did years ago. I bought spice tins with magnetic bottoms and just stuck them to the front of my stainless steel stove hood which has a lip on it the same width as the tins. They are very handy there right at the front of my stove hood. Here is a link to a number of spice tins that are already magnetic: </p><p>http://tinyurl.com/h7x69cw</p>
<p>ksis would love to see a pic of yours!</p>
<p>Thanks for the link for the spice holders, I've been wanting some like this, but they are too expensive at the Kitchen stores - these are very reasonably priced. Moving into a new house next month that has a cool metallic spice rack, and these will be perfect for those spices that are in ugly plastic containers.</p>
<p>All great ideas. I did mine with hexagon glass jars with metal lids from Amazon. Main reason, I'm obsessed with quality Pensky spices and the tins are not as seal tight, hence the cinnamon around the lid and the clump in the garlic from humidity. Definitely use heavy duty strength magnets. Has worked well using Gorilla glue for a short term but am seeing a problem of it cracking. Will use the JD Weld in the future and try the brilliantly simple idea posted of putting in the metal lid.</p>
<p>Although a fun project, this will cost a person way more than the $10.00 category that it's in. I LOVE using those magnets around the house but they're pricey. Over $5 a pack at Michaels for 5 (i think). Then to use 3 per tin = lots of dinero. So, in my area this would cost too much at one pop but I've spread out buying these as they are the best magnets. I want to buy them every time I go there but limit myself. I have to or I'd buy them all up! Fascinating to witness how powerful these are!!</p><p>Sorry, I got on a tear! </p>
<p>Try looking on Amazon or eBay for larger, bulk quantity purchases? Michael's is geared to smaller, craft-sized quantities (with their associated packaging and markup).<br><br>I see a quantity of 100 6mm by 1.5mm neodymium magnets from China on Amazon for under $10. (I'm not linking to it, since I'm not advertising for anyone specifically.)</p>
Wow, thats a lot of magnets! Now why didn't I think of that??<br>Thanks!
<p>I made a spice rack using these tins for my daughter (chose the clear to see the contents, just buy smaller amounts &amp; use up). Covered a metal sheet with wrapping paper and mod-podged, then inserted into a painted frame (also well mod-podged for easy cleaning). She lives in a turn of the century apartment building with white walls and hideous gray cabinetry, so purple is her go to accent color. For her I covered a metal sheet with purple foil wrapping paper (protected by mod podge) in a purple Victorian style frame with purple metallic pearl &quot;antiquing&quot; (also protected by mod podge for cleaning ease). The contrast between the modern canisters and the antique frame makes it look fantastic and, of course, it can be moved anywhere in the kitchen.</p>
<p>Just a thought. Since it is recommended to you keep most spices and herbs out of the light. I wouldn't recommend the tins with the see-thru lids. But, why not use the rectangle tins that you can buy the herbs in? You could put the magnet on the side; it's already labeled; it already has the perfect shaker/scoop hole for that herb, and they are usually cheaper than buying the herbs in the glass jars.</p>
<p>I want to do this on the inside of the pantry door, if so, I don't think the clear lids would be a problem. Nice post!</p>
<p>Hello, I am gathering all the supplies to make this; I was thinking to substitute the 3 small magnets with one &quot;disk-like&quot; magnet in the center of the tin. I was also wondering if little glass jars with metal cups (such as ball small canning jars) would be too heavy. Any advise?</p><p>Thank you.</p>
Single magnets can be strong enough if you get powerful ones. I originally tried magnet tape and wasn't pleased with how it worked.<br><br>As for jars, I think they'll be too heavy. Since the force on the magnet is parallel to the magnets surface (slipping) instead of perpendicular (pulling straight out), the magnet's force is much less.
<p>great idea, I've seen a version of this but yours seems well thought out. I believe I'll try this but I want to mount them on the wall between counter and cabinets. Is there a product that mounts easily to the wall? Like metal strips that don't require big holes to affix them? Thanks for the directions, I'm excited to try this out.</p>
<p>You could also just use metal thumb tacks or a nail. Place them at the correct spots by making some sort of stencil on a large sheet of construction paper. That would give it a sort of 'floating' look, which would be cool. Also, you could paint those thumbtacks the color of your wall or even an accent color (when you take off one of the jars, you see a cute little splash of an accent color). I've been thinking about doing something like this for a while now :)</p>
I think you can buy sheets of steel at most home improvement stores. As long as it is magnetic it should work for this application. To attach it to the wall you have a few options. You could attach with screws, 3M tape or even command strips. I think the latter might be the right option to get you started.
<p>How have I not seen this sooner, its great, thanks for sharing</p>
<p>cool project</p>
<p>Love it! Thanks for sharing this!</p>
<p>nice</p>
<p>nice</p>
<p>nice</p>
<p>nice</p>
<p>This seems like a lot of work to be honest! But I think that if you're lacking space in your kitchen for a good array of spices, this idea could really work out, not to mention be quite nice as a decoration too!</p>
<p>Haha. No work at all. You buy the spices, the magnets, the containers, you can even buy 100 round adhesive spice labels for 5.99 on Amazon. So easy. Stick label on, drop magnet on bottom of can inside, fill , stick on fridge.</p>
About This Instructable
444,255views
1,310favorites
License:
Bio: I'm just a guy that knows stuff about things.
More by ReeseLloyd:Disney Infinity Light FX Battery Mod PVC Kitty Condo 5 Minute $5 Cocktail Shaker
Add instructable to:
