How to make your own magnetic construction set by cesar harada
Featured
You love Lego? You like Knex? You love Bucky Balls? You like barbecue bamboo sticks? Well put that all together and you get "magnetic construction set" made with sugru! The idea is very simple : add a magnet at both ends of a barbecue bamboo stick, so you have a building block to build pretty much anything you like! Here, I cut all the sticks at the same length and I used quite small magnets (0.5mm ø), but you can use either smaller or larger magnets and sticks. In a matter of seconds you can build large complex structures :) You can invent so many games! The possibilies are endless!
Sugru is good for this hack because :
  • it bonds well with wood and metal
  • it creates a layer between magnets that makes it easy to do and undo sugru bonds
  • I could color code my sticks :)
This instructables was made for sugru.com at TechShop San Francisco
Step 1: Cutting the wood sticks to size
First you need to source the parts.
You could use other wooden sticks but barbecue bamboo sticks are great, they are long, light, strong, flexible, and cheap. I bought 150 sticks for one british pound (~1.5 $) at the corner shop.
The magnets are coming from Firstformagnet.com, they were the cheapest one doing next day delivery in the UK.
For USA delivery, you can get them here really fast : http://www.getbuckyballs.com
I use sugru : 8 coloured mini-packs in a lovely large pouch, each mini pack allowing me to coat at least 4 single heads.
  • £ 16.66 (~$ 25) : SuperCool GunMetal Magnet X­treme Neodymium Puzzle ­ 1 Premium N42 Official 5mm Size Spheres
  • £ 12 (~$ 18) : Sugru Multi-color 20g x3 and had 2/3 of sugru extra for other fun projects!
  • £ 1 (~$ 1.55): bamboo sticks
Total  : £ 29.66 (~$ 46.10) for a set of 28 sugru magnetic construction set sticks, but I could have made 3 times more sticks than that. I believe it shoudn't be too hard to make it cheaper than that.It took 2 of us about 2 hours to make, dried over night and was ready to play with. I think it is also possible to work faster.
First you want to cut the wood sticks to size. Because we are cutting many small things, I highly recommend using a metal saw (small teeth) to have a rather clean cut and avoiding cutting yourself. Wear gloves - not like me :)
macrumpton says: Jul 16, 2012. 5:32 PM
I wonder if you need magnets on all the ends? you could have ball bearings on one end of each stick and a magnet on the other, and I suspect that having one magnet at each junction would be enough to hold them together. Of course this depends on the magnet's strength.
cesar harada (author) says: Jul 17, 2012. 5:06 PM
Yes, awesome comment! I've been researching a bit and that's what I found : http://www.youtube.com/watch?v=RDbDEW7DSPw
That's so good! So, I guess I need to work on improving this system to make it even better than Bornimago! Next instructables!
msaleiro says: Dec 12, 2012. 8:48 AM
Great! Great! Great! :D Congratulations for this wonderful idea and thanks for sharing! :)
wolfkeeper says: Jul 16, 2012. 2:34 PM
If you get some steel ball bearings- steel ball bearings will stick to magnets even if two stick magnets are both the same poles (although it will be slightly reluctant). But it's probably better if you orient the magnet's poles at 90 degree angle to the stick
Also you could try cutting the sticks to a mix of 3:4:5 ratio lengths. That way you can build square-based triangles as well as equilateral; makes it a lot more flexible.
cesar harada (author) says: Jul 17, 2012. 5:07 PM
3; 4; 5; interesting ratios, yes! I'll try that next time!
bgoldberg1 says: Nov 16, 2012. 5:49 PM
Another ratio to consider is 1 : sqrt(2), which allows you to produce right-isosceles triangles.
Les Créateliers says: Oct 4, 2012. 6:09 PM
Sooo awesome! I posted you instructable on my website, you can see it here:
http://www.lescreateliers.com/Les_Createliers/Idees_Ideas/Entries/2012/10/4_Batons_magnetiquesMagnetic_sticks.html
Thanks!
Marie-Eve
cesar harada (author) says: Oct 5, 2012. 7:16 AM
http://www.flickr.com/photos/worldworldworld/8056651832/in/photostream
Thanks marie Eve !
je suis a Paris et je m'apprete a en refaire une plus grande serie pour un spot de pub, quand c'est edite, je le posterai ici :) a bientot ! Cesar
Les Créateliers says: Oct 5, 2012. 8:07 AM
Wow super! Félicitations!!! J'ai hâte de voir ça!
gserrano701 says: Aug 20, 2012. 6:19 AM
Great idea, nicely done instructable, thanks.
HEY YOU says: Jul 30, 2012. 9:11 AM
Nicely done Instructable!!
I love the creativity that comes from this type of "toy"  My daughter has a set of Straws and Connectors and long after she is bored, I find myself rebuilding and creating new structures and creatures....
As to the legality of Bucky balls, it is simple, DO NOT GIVE THEM TO YOUR KIDS!!!!! Oh and DO NOT EAT THEM!!!!! Why is it that the American Government gives their citizens so little credit for common sense??????
Anything that will fit through a toilet paper tube is a choking hazard!! Yes,  Magnets are hazardous if two of them are in the intestines at the same time, but come on people, Stand up for your right to exercise your common sense.
Cheers
waynevanwijk says: Jul 29, 2012. 3:43 PM
It looks like fun.
It may be cheaper and also avoid any issues with polarity to just use ball bearings on each stick. Then all you need is a single spherical magnet at each junction to hole things together. This would greatly reduce the number of magnets needed. Perhaps the magnet could have it's own sugru coating in a contrasting colour to the sticks. This would be less elegant than what you have done though.
criggie says: Jul 29, 2012. 6:53 PM
Magnets are a swallowing hazard - they can screw up your insides badly, especially if two attract through the intestine.
Sounds stupid I know, but our puppy would quite happily eat a sugru-covered magnet. He's already disposed of a hard plastic hair clip.
Babies would chew the sticks too, so I'd suggest attaching things very well.
waynevanwijk says: Jul 30, 2012. 1:23 AM
Yes, I totally agree about magnets being a choking hazard. The method I described would only be good for a pet and child free home. I have three little kids here and would hate them to get magnetised to each other ("Dad, he's touching me").
It is definitely best to keep all the magnets attached to the long sticks. That way if they do get swallowed all you have to do is pull on the stick to get your magnet back ;-)
cesar harada (author) says: Jul 30, 2012. 12:44 AM
Thanks Criggle for the pro-safety advice, I concur. Please keep use this toy only with +5 kids and under surveillance. Do not let animals play with these.
cesar harada (author) says: Jul 29, 2012. 4:11 PM
You are totally right !
But... I really like to be able to do that with only sticks - and no balls at the junction... hhummmm dilemna. Maybe i'll build one set like that and see how it feels - thanks for the suggestion !
Skymeat says: Jul 29, 2012. 11:38 AM
Buckyballs are now illegal...So get em while you can!
cesar harada (author) says: Jul 29, 2012. 12:10 PM
OH !!! NO !!! I didn't know that! Thanks for letting me know!
I just researched a bit - it is still totally legal in the UK. Seems like British babies are not too much into eating magnets... that's smart :)
Skymeat says: Jul 29, 2012. 1:30 PM
I would expect they are much smarter :)
jcbeaver7 says: Jul 27, 2012. 4:24 AM
I threw out my old buckyballls a few days ago because the outer shell was worn off.. I couldve used it for this :P i like the instructable though
randofo says: Jul 26, 2012. 12:19 PM
Cool. I like what you have done here. Very clever!
studleylee says: Jul 16, 2012. 2:08 PM
I Love This!!! I tried on a much smaller scale and had some issues with magnet polarities. I will try the spherical puzzle magnets. Awesome!!
cesar harada (author) says: Jul 17, 2012. 5:36 PM
Thanks !
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
