3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magnetic Tool Tower
Magnetic Tool Tower
Loosing your tools? Cluttering your desk with 12 different screwdrivers? Then you need the Tool Tower.  Tool Tower uses space age technology to hold your tools out of the way of your work space, but easy to access!
Step 1Supplies
What you need:
Wood
Hard Drive Magnets (i used about 12)
Screws
Drill/Driver
10 comments
Nov 28, 2011. 4:08 PMRangerJ says:
I like it; I like anything that will organize my tools.
Sep 30, 2010. 4:41 PMrimar2000 says:
These magnets are awesomely strength!
The idea is good, but note that sometimes magnetized screwdrivers or tweezers are very annoying.
BTW, I am anti-anti-anti! ;)
Oct 23, 2010. 6:14 PMagis68 says:
I am NOT!!! on the other hand you can get antimagnetized....;))
Feb 23, 2011. 5:39 PMpfred2 says:
It is called degaussed. I actually have a tool degausser. You DO NOT want twist bits magnetized if you are drilling ferrous metals! Though I do use a magnet on my mill to hold its chuck to it. See if you can find the electrical box being held up by a magnet in this picture:
http://img837.imageshack.us/img837/9348/003sk.jpg
BTW my degausser is behind the motor on the mill against the wall.
Feb 23, 2011. 6:14 PMrimar2000 says:
I can't view your link, Imageshack demands register before, but I don't want do it.
Feb 23, 2011. 7:28 PMpfred2 says:
Strange I never heard of that. Thanks for letting me know I'll find another hosting service that doesn't.
Oct 4, 2010. 6:40 AMepotter says:
Is there any way you could use ball bearings to make the top portion rotate. I'm thinking this would be cool to modify with metal and magnets to hold notes, etc on your desk.
Oct 2, 2010. 6:14 AMgeppetto425 says:
Great idea! I'm a woodworker though and you should never glue end grain to end grain. The way the wood cells are aligned it makes for a very weak joint and polyurethane glue is inherently about 1/2 as strong as PVA glues, so if this were dropped on the floor it would probably fall apart! If you have to glue end grain to end grain strengthen it first with some steel rods or holes filled with epoxy....
Oct 2, 2010. 1:01 AMDiabloscope says:
you could have just drilled holes in the wood at an angle keep them more organized and yes rimar2000 , magnetic pliers are annoying , i use a little tweeter magnets for screws ........................... To Each His Own !!
Sep 30, 2010. 9:13 PMmikeasaurus says:
nice!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
399
Author:frenzy
I'm the QA engineer here at instructables. I make cool projects in between testing instructables.com to make sure it works awesomely. Give me your bugs!
