3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magnetic stripe card spoofer
Step 6Test it
Test it
Make sure the amplifier is on, and play the .wav file containing your data on the music player. If you've done everything right, the electromagnet should transmit the data from the card you're emulating.
If there's a problem with the transmission, try playing with different combinations of gain on the amplifier and volume on the music player. If the signal is too low, the magnetic field produced won't be strong enough, and if there is too much gain, the signal will be distorted.
Some music players cut off the first split second of things that they play. If this happens, your data will obviously not be transmitted properly. You might have to mess with the C++ code or use an audio editing program to add some silence at the beginning of the sound file if this is a problem. I was able to get around this with my iPod by making a playlist that has a .wav of silence before my data file.
Also, mess with the positioning of the metal tab you might have to move it around a little to find the "sweet spot" where its magnetic field is pest perceived by the reader. Additionally, make sure that it is thick enough to trigger the "card present" switch in the card reader.
It took me a few days to get settings that worked, so don't give up if you don't get it perfect on the very first try.
Good luck!
4 comments
Aug 3, 2008. 3:01 PMGiggles12 says:
I think nerds are hot!
Apr 17, 2010. 11:06 AMNatureTM says:
Fact Check:  We are ugly.
Sep 9, 2010. 10:48 PMcody777 says:
speak for yourself
now if only i could find a girl who was hot AND as smart as me
Mar 6, 2010. 10:57 PMthestyrofoampeanut says:
 that kinda sorta just really made my day
Aug 7, 2008. 12:33 PMwaterppk says:
Nice to hear someone has some love for us, but it doesn't make the cold nights any warmer :P
Jun 24, 2010. 10:01 PMNatrix2494 says:
exactly, knowing C++, C#, in highschool doesnt mean a thing to anyone.. we stay nerds cuz we know one day it will mean something..
Oct 22, 2009. 9:36 AMcrasymonkey89 says:
is it possible to use these on say a card reader without a track?  I.e. a system wherein you simply hold the card to the reader?
Nov 14, 2009. 1:53 AMejreynolds says:
Unfortunately, no.  That type of system is usually RFID (http://en.wikipedia.org/wiki/Radio-frequency_identification).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:powerpants
