Magnifying Eyepiece
3,355
12
Published
Introduction: Magnifying Eyepiece
I sometimes need to solder fine-pitch electronic parts which I find to be impossible without some visual magnification and since I also need to use both hands while soldering, I made this eyepiece.
This is an after-the-fact instructable, so I do not have very good step-by step instructions..
My apologies..
Parts List:
1) magnifying lens .. I found this at a local surplus store, but these type of lenses are fairly common.
2) 1.5" diameter ABS plastic pipe coupler .. I used some scrap that I had lying around, but you can find ABS pipe couplers at your local plumbing supply store.
3) two mini key-rings .. optional.
4) elastic chord .. try you local sewing supply store.
5) sunglasses strap .. you can find these most anywhere.
Step 1:
1) Using ABS glue or epoxy, glue the magnifying lens into one end of the ABS coupler
2) On each side of the ABS pipe coupler, cut two 1/4" holes and slip the 2 keyrings through the holes
3) Cut two 3" lengths of elastic chord and  attach the sunglasses strap
4) Smooth the edges of the end of the coupler that will be against your face.
Step 2:
You're done.
Sorry for the lack of details in this instructable, but I hope that I have given you enough info that you can create your own version.
Step 3: Example of Fine-pitch Electronics
Here is an example of a circuit board that I soldered with the help of the magnifying eyepiece.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    This is a brilliant idea, welldone
